the OP’s amp has a lot of corrosion. That is what you are seeing. Those solder joints have never been disturbed
hey Wally,
I agree that it could be fender soldering.
i am saying that it is below standard fender soldering practices.
thanks
pete
hey Wally,
thanks
pete
ime, here is no problem, and I see typical Fender factory work.
So, job done.
I've also replaced the 2w bias resistor with the 3w and switched position with the cap.
The volume is improved a lot but still not at the same level of the 62 Fender Champ, is it normal and it will never be like the 5F1 or am I still missing something?
I see.A 1962 Champ is a 5F1. Ime, that amp will have more ‘oomph’ because the more elaborate tone stack in the AA764BF/SF Champs neuters those amps to some extent. There may also be a difference in the speaker efficiency Depending on what speaker you have in the ‘62?? There could also be a difference in the operation of those two power tubes. In a cathode biased output, the tubes determine how much current draw occurs in the circuit.….different tubes are cooler or hotter depending on the particular tube’s operational parameters.
I switched the tubes and the respective volumes stay the same, however in the Champ on B+1 there are almost 400VDC, it makes 60V more than the VC, I guess that is why the volume differences.@maybeoneday, if you want to hear the difference in the power tubes, simply switch them. There may or may not be a difference. It could be an interesting experiment. I like to know how a power tube is Biasing in these little single-ended amps. There can be a wide variation in plate dissipation, and that will determine what the amp sounds.
If your joints failed, then I suspect you need a better iron.
I cannot download the JJ exercise above. Also, what is a CIETES 5Y3?
Maybe you have run into a batch of JJ 5Y3s that have a problem In the production process. Are the JJs new tubes? I have never used JJ 5Y3s. Their GZ34 has been a good tube for me. I would run a NOS 5Y3 in that VC.
