maybeoneday
Hello guys,
I have a problem with volume on my '64 Fender VibroChamp.
The volume appears to be very low even for a 5 watts amp. The strange thing is that it is completely random, sometime increase but the next day is again low.
I tried to poke around with rectifier and power tube, replacing them for others which I know they are working but still no consistency.
The amp is pretty much original, only some caps has been replaced but PT and OT are still the originals.
I took the voltages from PT, Rectifier and Filter cap and I think they are a little low even tho the PT secondary is at 334V, they are as follow:
PT secondary 334VAC
Pin 8 Rectifier 313VDC (335VDC when I increase the speed and intensity of the Tremolo)
B1 313VDC
B2 285VDC
B3 265VDC
Even replacing the rectifier the voltages are pretty much the same.
Note: the 2 prong power cable has been changed to a 3 prong. Being in Europe I am using a Voltage converter but it shouldn't be a problem as using it for my '64 Deluxe Reverb and '62 5F1 Champ.
PT secondary 334VAC
B1 313VDC
B2 285VDC
B3 265VDC
