1963 Vox Shadow Inspired Budget Build
Discussion in 'Tele Home Depot' started by guitarbuilder, May 26, 2019.
  1. guitarbuilder
    I inserted the newly threaded rod into the bolt with the hole in it. I peened the end over to help secure it. Then I hacked if off the bolt. r4.jpg
  2. guitarbuilder
    I did a little filing to remove the sharp burr. Now it looks like a regular truss rod. I ended up drilling down into the poplar a bit farther with a " bit"....:)
  3. guitarbuilder
    I had to chisel a little space for the peened over rod at the end. I chased the other end with the die while it was convenient. Now to make a filler strip.
    Freekmagnet, crazydave911 and CraigB like this.
  4. guitarbuilder
    I had to put a dummy rod in the slot to get the filler strip in place so I could drill a concentric hole for the truss rod nut. I used a shrink tube on the length of the rod to fit it snugly to the slot. It's green.
    The rod was installed with a little dab of caulk at the ends and the middle. too. A few clamps held it down during the yellow glue drying process.
  5. jfgesquire
    jfgesquire Tele-Meister
    Lake View
    That dark wood along the upper edge reminds me so much of the Harrison/Clapton "Lucy"
    That alone would be enough reason for me to watch this build.
    Nice.[​IMG]
    Sent from my LG-H932 using Tapatalk
  6. guitarbuilder
    That's Indian Rosewood on my fretboard. Lots of that was/is used on guitars.
  7. epizootics
    epizootics Tele-Meister
    Lyon, France
    I believe he was referring to the body itself, with the 'upper' side of the glue-up a wee bit darker than the rest...
    Good job on the neck, for some reason I love watching people making their own trussrods...
  8. guitarbuilder
    Ah...good eye. It's just basswood to me....:) I think it's important to have truss rod making skills. It reverts back to the old days when double rods MIC didn't exist...
  9. guitarbuilder
    Filler strip cut off, planed down, and finally scraped level.
    Tom_ likes this.
  10. guitarbuilder
    Nothing here to see...….
    crazydave911 likes this.
  11. guitarbuilder
    After a ruined fretboard yesterday, I sat down and redid x carve specific files for this fretboard today. First I ran the 12" radius program.
    Roughing:
    Finish pass:
    A finish pass
  12. guitarbuilder
    I scribed some fret slot locations with a vee shaped Dremel bit.
  13. guitarbuilder
    Next I machined in the dot holes:
    nickhofen likes this.
  14. guitarbuilder
    Next was a tapering program:
  15. guitarbuilder
    And lastly I cut two parallel cuts on both sides to have a reference edge ( I hope) against the fret slotting miter box side.
  16. Muddslide
    Muddslide Friend of Leo's
    Gypsy Caravan
    This is so cool. Can't wait to see the finished product!
    When you get done, would you build me a replica Vox Apache? My birthday is coming up.
    Thanks in advance.
    Here, I'm a helper. For your inspiration:
  17. guitarbuilder
    Thanks! I'll see what I can whip up.
  18. guitarbuilder
    I squared up the fretboard to the straight routs. I also punched out some scrap pickguard dots. I love dots at no cost. They got glued in with Duco...the acetone based stuff in the green tube.
  19. guitarbuilder
    Today I sawed the fret slots. I used the stewmac template just to raise it up. I lined the blade up to the scribed v groove and held it in place by hand and cut down.
    Slot number 18 got a little wider than I'd like, so I'll have to attend to that. I glued and clamped it to the neck with a caul. The fretboard is pinned with 4 brads that get removed when the clamps come off after 30 minutes. That way the glue is still cheese-like and easy to remove. This is my typical method and you can see it all in the "let's make a neck" thread if you are so inclined.
  20. guitarbuilder
