1959 Les Paul Jr. Build
Discussion in 'Tele Home Depot' started by Scatter Lee, Jan 21, 2010.
  1. guitarbuilder
    It looks like a rhino beetle and why am I experiencing deja vu with this thread? Wasn't this thread up here a few weeks ago? Did you make another JR? Another Case?
  2. guityak
    guityak Tele-Meister
    Albany WA
    Nice job. How much does the case weigh? I have been contemplating building my own to hold two guitars.
  3. Runn3r
    Runn3r Tele-Meister
    australia
    fwiw i reckon it will work upside down since it is a 2 way truss rod
    the orthodox install is for the adjustable nut to be below the non adjustable rod (fingerboard being topside)...and typically at the neck heel end
    the case is pretty awesome btw
  4. guitarminator
    guitarminator Banned
    warwick RI
    speaking of bugs, this thing hit the house like a rock, had to get some pics of it
    coolest colors on a bug i'ver ever seen
    [​IMG][/QUOTE]
    WIGN is that? OMG looks like something from an Alien Movie !
    Was/is it still alive?
  5. mlp-mx6
    mlp-mx6 Tele-Holic
    Atlanta
    True. If the adjustable rod is on top you will turn the nut opposite of convention. Lefty tighty, loosey righty.
    No. Only for a Fender-style neck is this true. The double rod is designed to turn heel-wise or headstock-wise. It does not care.
  6. Scatter Lee
    Scatter Lee Friend of Leo's
    follow the buzzards
    heres the trussrod, i put them in my last two builds and then bought 5 more, and they work great
  7. Scatter Lee
    follow the buzzards
    Was/is it still alive?[/QUOTE]
    when it hit the house i thought someone was throwing a rock at me, tried to get good pics but the true colors would not come thru in the pics, then it spread it's wings and flew away
  8. Scatter Lee
    follow the buzzards
    i cut some cardboard today and sprayed some super 77 adhesive on it and stuck it to the back of the cloth
    stuck it in there
    used a template to tuck everything in
  9. Scatter Lee
    follow the buzzards
    trimmed it up with a razor blade
    then i glued some soft foam in the middle of the hard foam
    and glued the cloth down
    and trimmed it up with a razor blade
  10. Scatter Lee
    follow the buzzards
    there it is, ready to ship
    guitar weighs 7 lbs, case weighs 18 lbs
  11. woodturner
    woodturner Tele-Meister
    Idaho
    I'm getting ready to try making a neck. It will be my first attempt. Which truss rod is this and who sells them? Not having to route the curved recess should simplify things a bit.
    Nice build by the way.
    Regards,
    Bill
  12. Runn3r
    Runn3r Tele-Meister
    australia
    ...i don't disagree with all this
    ...however, it might get confusing when it comes time to adjust the truss rod if a person were not mindful of the above (counter clockwise to correct excessive relief and clockwise to correct backbow...which is the opposite of the usual 'orthodox' nature of truss rod adjustment)
    ...i reckon though scatterlee will include instructions :D
    ...i mean he's made a case! ;)
  13. Mojotron
    Mojotron Poster Extraordinaire
    Seattle
    Hey Scatter Lee - I made your fingerboard radius jig very similar to this one above:
    It's great - only took me an hour to put together with some 1.5" thick plastic pipe, 2 (really straight) 1.5" steel angle pieces and some MDF. Here's some pics of my base:
    My router base is very similar - since I'm only making 12" radius necks right now, I made the base using a 13" circle jig cut. Since the base has a 13" radius and the router bit rides 1" below the base: 13-1=12" radius...
    I placed the angles (with the pipe taped to the angles - same as in your jig thread) exactly 6" apart by using an precisely 6" wide (+/- .01") piece of MDF to separate them. Then I just clamp them all together really tight and it makes a very precise fretboard radius - way better than I could ever do with just a radius sanding block. Best of all it only takes 5 minutes to slap some double-sided tape on a neck and get the fretboard completely radiused.
    Thanks for showing how you did that in your previous threads, each jig I get put together makes building a lot more fun and way easier.
  14. ksharpe10
    ksharpe10 TDPRI Member
    orlando,florida
    I made a case similar to this for a les paul standard back in 1976, It weighed like a rock, you could throw it down a flight of stairs. To heavy. I think hardshell cases are bent wood similar to how they build acoustic guitars. The guy getting it will probably use a well padded gig bag. And use the case for display purposes. Good job though. They did not have, that I know of, in the 70's the Good stuff or Great stuff sprays. I used the upholstery foam. My mom had left over from furniture restorations.I used Door hinges.And covered the outside in green naugahyde, the interior was dark green crushed velvet, looked good with a guitar inside it. And used a ton of contact cement. To Heavy. LOL.
  15. Scatter Lee
    follow the buzzards
    yeah, it's on a UPS truck now, thats what it was made for
  16. PaisleyIsGod
    PaisleyIsGod Tele-Holic
    Halifax
    I love this thread. Amazing work! My girlfriend loved the gator pics too.
  17. koolaide
    koolaide Tele-Afflicted
    south carolina
    Let's face it Scatter is so cool even his bugs are awesome looking.
    Thanks for sharing your skill and knowledge. There may be some who get more done, but not with less, and I venture to say not nearly as well either.
    Just goes to show-It's not whats in your shop that counts, it's whats in your head and hands.
  18. Scatter Lee
    follow the buzzards
    nice,
  19. ksharpe10
    orlando,florida
    I just remembered more details about the case I made years ago. It was also made out of plywood. Scats pine prob. is lighter. Scat also has a lip on the edge which seals alot better too. Everything looks so great. And thanks for all the jigs and build tips, oh and Bugs, too.
  20. Scatter Lee
    follow the buzzards
    the main thing i was after was no twist and basicly crushproof
