1959 Les Paul Build
Discussion in 'Tele Home Depot' started by preeb, Jan 14, 2010.
  1. preeb
    preeb Poster Extraordinaire Vendor Member
    Sonoran Desert
    Yes... Made in USA Model M... the only one I can use... the new ones are horrible. I like the feel and sound of it + it has that perfect high action too... you know... (-;
  2. '59_Standard
    '59_Standard Tele-Holic
    Worldwide
    Gil, in relation to what Nuance97 asked about the dyes.
    The TransFast is (I suspect) Code: FTBR
    LMI Page 1
    And the other Red is (I assume) is FSTR
    LMI Page 2
    Earlier - pg30 - you wrote :
    "I'll add dark red pigment to the filler which will not fade in UV "
    So is that another Red Dye than the above two or one of them mixed - which I think Nuance is aso refering to.
    Thanks!
  3. preeb
    Sonoran Desert
    Oh... I thought I mentioned that...
    Yes... the above FSTR are for the red clear and top. A different pigment color set was used for the filler which is more UV resistant (same stuff I use for the pre-CBS 64-65 burst red). It doesn't mean it will stay forever red.... but it will fade much slower than the 59 type aniline into the expected beautiful original faded look.
  4. preeb
    Sonoran Desert
    For those who have naturally reliced the refresh button... I'm in the "waiting zone" again... and unfortunately, that's how it is with protos... constantly testing and changing stuff... sorry (-;
    I'm expecting a first bobbin batch today... if it's good enough I'll use it.. but if not... we're back in the molding game again...
    The reason I'm not doing the top yet are the new STP inserts that were made for me with 100% historically correct specs (Material and shape...). They should be inserted prior to finishing... and I'd like to use them for the proto instead the ones I currently have which look good but made of a harder steel which is a big tone killer for Lesters...
  5. Sterling Sound
    Sterling Sound Tele-Meister
    The Hague
    Hilarious :D
    Trying to find a way to always get to the last page of this thread..
  6. nuance97
    nuance97 Tele-Meister
    Georgia
    I'm trying to take in all of this info, but a couple more questions..If you don't mind. When you say 59/39/2 do you measure this in droplets? How much of the dissolved dye mix [dissolved in mineral turpentine I now Know] do you combine with how much filler? From the photo it looks like maybe 1/4 or 1/3 cup?
    Is mineral turpentine the same as mineral spirits? Or is it two different things?
    Here again measured in droplets? And from the pic it looks like the dye/thinner mixture is added to maybe 2 or three ounces of lacquer?
  7. preeb
    Sonoran Desert
    Masking is removed from bindings
    No bleedind for now... very good!
    Door is opened for direct sunlight... so color is more realistic
    Still waiting for the inserts in order to proceed with the top color.........
  8. Scott Auld
    Scott Auld Tele-Holic
    South Florida
    What kind of grain do you get in gopher wood? :D
    LOL - classic!
    I always keep a preeb thread open in a tab in the browser. I never close it. And I'm always sad when the posts dry up because the guitar was finished a month earlier! :)
  9. Scott Auld
    South Florida
    PS - I never close the Emeraldcaster thread either! Always open in a tab. :)
  10. preeb
    Sonoran Desert
    V$#V
  11. nuance97
    Georgia
    Thank you very much! =D
  12. QuickDilation
    QuickDilation TDPRI Member
    Detroit
    Gil! I need my fix! It's killing me, this thread is like crack! :p
  13. preeb
    Sonoran Desert
    Sorry... not my intention... but we'll get to the cracks in the final relicing stage (-;
  14. preeb
    Sonoran Desert
    An early bird... new bobbins arrived at my doorstep!
    vintage correct size and tooling marks... etc...
    Very nice material too...
    Minimum quantity of a few hundred black sets... and only a few white samples. I should have asked for the slug side whites...there's nothing to do with them right now since the standard zebras have the white bobbin for the slugs.
    The white color is superb though... see it against my M-69's.... beautiful!
    compared to the current best available vintage bobbin... note the correct Ivory compared to the slightly pinkish color... there's also slight "depth" to it if you look closely... nice material indeed...
  15. oigun
    oigun Tele-Afflicted
    Haarlem, Holland.
    Is the taptone correct on those bobbins?:D
  16. preeb
    Sonoran Desert
    And for you purists and PAF nuts... yes... it even has the little round tooling mark on the slug side bobbin (-;
  17. preeb
    Sonoran Desert
    I'll need to unwind the original test PAF again in order to check that... but I guess not. It's probably very close but the original CAB material is a little bit more flexible TMO.
    As much as I love those (They *ARE* great don't get me wrong!) I can still imagine myself molding my own in the future.... unless someone else will do it first and offer them at a reasonable price (but we all know this will never appen). It will be a 3 part mold... a complicated one too... We'll see...
  18. dynamohum
    dynamohum Tele-Meister
    Liverpool
    Gil, what are you going to be using for your tailpiece? I recently had an "interesting" coming together of an aluminium tailpiece and the melting point of said material... Live and learn and all that, but I'm now looking for a replacement - the original tailpiece (on a 1980 LP Custom) is still available as a reserve but it's so heavy. Think it's zinc or something. I prefer something lightweight for that "vintage" vibe :).
  19. treadwm
    treadwm Tele-Meister
    Brunswick, Maine
    They are two different things. They are often recommended for the same purposes but the outcome is sometimes very different.
    For example, I use Sherwin Williams sanding sealer thinned down in my wood turning. The can sez to use either turp or mineral spirits to thin. If I use turpentine, no problem. Use mineral spirits (also sold as "oderless turpentine") and the solids flocculate and settle to the bottom. Not very good for sanding sealer. :)
    I'd stick to the real turpentine, esp since Gil said that's what works for him.
  20. preeb
    Sonoran Desert
    melting point? What are you talking about?!?!?
    I have a few I made long ago from an original
    but the master was "fixed" and "cleaned up" a little too much and some of the original tooling marks were gone in the "cleanup process"... long story... don't ask... another one of those experiences where you learn that in order to get something done right you either have to do it yourself or at least be there when it's done. I don't even own the mold... but it's still the best repro I can currently use and it doesn't respond to strong magnets like all the newer "Aluminum" ones... LOL
    I'm planning a new batch with Marc... we have many things going on at once so I'm not sure if or how soon before it's made... it's definitely in the pipe though.
    If you don't mind the magnetic attributes on the newer stuff you can get the Gotoh Aluminum STP. It's not super accurate... but it's not over priced either... very good value for the money!
