1959 Les Paul Build
preeb
Vendor Member
Sonoran Desert
Guitar is prepared and blown with lots of high pressure air to remove any tiny left over particles. GT is a tough one to get right because every minor scratch or overspray particle will damage it. No sanding no nothing... you'll have to remove the whole thing and start over... (-;
The room is sprayed with water mist right before the gold is applied.
I shake the gun a little to get a good powder flow and spray 2 misty coats real quick.
The room is sprayed with water again and I repeat with two additional misty coats to get 100% coverage.
It's very important to do misty coats rather than wet. I also get a bit further away with the gun like you normally do any metallic color. This is the reason I prefer a cheap regular gun (as opposed to HVLP) to get better atomization with a higher air pressure. They didn't have HVLP's in 1956 as well (-;
That's basically it... it only takes a minute if you do it right... but if the surface is not prepared properly or there are contamination problems or the spraying technique is not correct it will take a few hours to sand it all off and start from scratch.
I inspect the gold closely to make sure it's perfect and that the particles are placed nicely. Note the grainy look that I got from that powder mix.
I lock the GT with a single misty lacquer coat and remove the masking tapes.
It looks different from every angle and lighting so it's hard to capture in my cellphone camera but you can get the idea...
I'll let it cure for a day and scrape the binding tomorrow.
Next are the clear coats. The first two will be done with the GT gun to get some gold particles in the clear and the final two will be amber tinted old lacquer top coats which will give it it's final warm gold color.
Lot's of finishing coats on a GT... that's why they crack like they do...
preeb
Vendor Member
Sonoran Desert
Chicken fat and car exhaust scrapings Gil......you never cease to amaze me. Your threads are always pure entertainment :)
LOL... I know it sounds bad... but I'm not at all like this (-;
I wish everything would be available off the shelf, like...
"Excuse me, where's the '1956 gold top painting kit' please?"
"Ahmm... Look in the Gibson department, finishing section at the second floor to the right, if you can't find it ask for Orville"
preeb
Vendor Member
Sonoran Desert
Just noticed that the photos of the GT after spraying came out so so... the actual color is the one shown in the scrap test and in the can. I'll take better shots later with good lighting.
neighbour
Israel
And you know that even if it was exactly like that, when you come and look for it it will be like in the military: "we just sold the last one" go scrap your car's tailpipe :lol:LOL
preeb
Vendor Member
Sonoran Desert
I can now see that I have many double photos where one is darker and looks OK and the other is lighter and colorless... It has to do with my new iPhone camera I think. There's an HDR function that does that for some reason... anyway, I took the darker version and replaced the bad ones I posted earlier so the colors look closer to reality now.
preeb
Vendor Member
Sonoran Desert
Hey... we served in the same military!!! but who thought of GT's back then...
Engraver-60
Brentwood, TN
So, tailpipe exhaust carbon is the missing ingredient. Grandma use the same trick in her Kreplach:)
And the bronze is the copper component that caused the sweat reaction of green oxidation. Very cool, indeed. I love your ability to reverse engineer. Are you sure you're not Japanese? Thanks, Gil.
Mojotron
Seattle
Ahhh - having owned a really old GT back in the 1970's (not sure of the year), I would say that close up of the practice spray takes me back. Amazing work Gil!! Thanks for the notes on how you did it.
preeb
Vendor Member
Sonoran Desert
The Kreplach part was great (-;
preeb
Vendor Member
Sonoran Desert
Here's an original 56 close-up against our build. Note the texture, color and grain size.
MRJ.
West End, NC
What brand is the powder you're using? Do you know if there are any places on the internet that have it?
preeb
Vendor Member
Sonoran Desert
You are a very lucky man, you're getting the best there is! :lol:
BTW Gil, you know about this brand right? That picture of the Nescafe with Goldtop paint was very funny ;)
Ha... I never saw that gold Nescafe here in Israel. All we get is the red stuff.
How different is the Gold one?
BTW, those jars are great and their lid is air tight, making it perfect for lacquer and paint roof storage.
My constructor (who's currently building the new shop) didn't know that all those jars I put on the roof are not junk... don't ask... I had to dig through a pile of construction trash and open every sack but only managed to save about half of my aged Cherry and Clear nitro. I already knew some was lost because I could smell it down the street (-;
preeb
Vendor Member
Sonoran Desert
There's no label on the can but I can ask the girl in the hobby shop and post it here if it helps (probably a local manufacturer though).
I'm sure you can find this stuff in many hobby stores or places that sell Feng Shui materials. Look for the cheap rough powders and not the fine expensive ones. The key is gold color (not copper) and larger grains .
MRJ.
West End, NC
You don't have to go to any trouble. I'll do some looking around and see if I come up with something. By the way, the guitar looks really great. As always. Can't wait to see the p90 builds.
