1959 Les Paul Build
Discussion in 'Tele Home Depot' started by preeb, Jan 14, 2010.
  1. Dalton
    Dalton TDPRI Member
    europe
    I forgot to ask. What kind of ink did you use? The ink surely has to be water resistant.
  2. preeb
    preeb Poster Extraordinaire Vendor Member
    Sonoran Desert
    It's a decal paper I make. I use heavy white paper sprayed with thin white glue (gel) and a thin film of nitro. This way the ink is protected on both sides after top coated and submerged in water.
    You can also buy it online I think... but without the lacquer of course.
  3. Dalton
    Dalton TDPRI Member
    europe
    I understand. You are great! So my last question has already been answered. Thanks!
  4. nuance97
    nuance97 Tele-Meister
    Georgia
    Have you ever detailed this in your other threads? I haven't read them all...yet.
  5. Dalton
    Dalton TDPRI Member
    europe
    I think a fenderlike decal has to be produced in another way, cause there´s always a real foil under the finish. This serialnumber on the headstock now isn´t a decal anymore. It´s pure ink melted into nitro. Great!
  6. Dalton
    Dalton TDPRI Member
    europe
    I´ve got a question again. You talked about the tapering thickness of the fretboard to get an even hight for the binding. I´m not sure what´s the best way to realize this. You first did the tapering and after that the slotting. If you first do the slotting on a board with an even hight, the slots will be really in a 90° angel. The tapering could be done from the other side. I just think about it. How did it Gibson to realize a quick production.
  7. sasparilla
    sasparilla TDPRI Member
    Germany
    The Back Color is perfect as far as i can tell from the Pictures, how long it has to dry before final sanding and buffing?
    Do you know if the Serial number on the original was stamped into the wood a little bit?
    I would love to see some high quality Pictures from that Guitar, the CellPhone quality doesnt justice to the Quality of your Work :!:
  8. preeb
    Sonoran Desert
    Good point. Thank you!
    I believe the angle difference is close to nothing, probably around 1/2° or so,
    but I'll definitely take your advice into consideration in my next builds. I'm not even sure that my slot cutter is that accurate and capable to produce an exact 90° cut though... LOL
    As to what Gibson did... that... you'll have to ask them.
  9. preeb
    Sonoran Desert
    What final sanding? I haven't applied the clear coat yet (-;
    The serial on earlier 50's Lesters was definitely stamped over the sealer... on Bursts... I don't know. Probably the same as they look the same to me.
    I hope I'll never find out for sure... (-;
    I'll do the final shots with a good camera... I promise. Maybe even a sound clip...
  10. QuickDilation
    QuickDilation TDPRI Member
    Detroit
    Back flows much better now with the burst, definitely notice a difference!
  11. 68thinline
    68thinline Tele-Afflicted
    Hoggetowne, FL
    Thank you for the correction. You are absolutely right.:D
  12. Dalton
    Dalton TDPRI Member
    europe
    You have to
    Yes, that angel is close to nothing. Or maybe the effect of first tapering and 2nd slotting is good because the saddleline (fret zero) has to be filed back to 90° what makes the saddle move a little forward. Even if it´s almost nothing it´s good for intonation.
  13. preeb
    Sonoran Desert
    I like your thinking Dalton!
  14. 68thinline
    Hoggetowne, FL
    Wow. Just catching up on the last few pages since Friday. That burst is stunning - the tinted nitro top will make it perfect I'm sure.
    I hope you don't get tired of compliments and thanks again for sharing all of your wonderful insight and knowledge.
  15. Dalton
    Dalton TDPRI Member
    europe
    to get it perfect straight:
    lay the fretboard on a straight surface and take a simple wooddrill with a centered tip in the diameter of the fretboards rimhight. You can tune that height with a feelergauge under the drill. Mark the points where to drill by handspinning. After that you can use your manual drill.
    to get it perfect off:
    use different feelergauges under the drill
    :D
  16. chillman
    chillman Tele-Afflicted
    Preeb-first of all, what can I say that hasn't been said. I'm in awe. This is a work of art with an attention to detail that is completely unmatched in this disposable culture.
    Will you be aging this guitar? I don't remember if you mentioned that or not.
    Sorry if that question has been answered ten times already.....I didn't feel like looking through 2000+ posts to find it!!!
  17. preeb
    Sonoran Desert
    Thanks chillman,
    Yes... I'll relic the thing...(-;
  18. preeb
    Sonoran Desert
    LOL... Thanks Dalton.
    I was only joking.. I thought it was obvious.
  19. twoguitars
    twoguitars NEW MEMBER!
    spain
    hey preeb .. i've found this on my guitar-tuner box...
    “When love and skill work together, expect a masterpiece.” John Ruskin
    I believe that it is a thought that describes perfectly your way of working and understanding the guitar....
    best regards
  20. preeb
    Sonoran Desert
    Thanks 68thinline.
    How can one get tired of compliments (-;
    Seriously though... I was really expecting more inputs from LP experts.
    It's a huge task to gather all the info, materials, blueprints....etc... and it's a complicated instrument to build correctly... so.. it makes no sense to me that no one has pointed out better ways to doing things or correct my assumptions...
    I'd much rather have criticism than compliments... criticism I can use to make things better... (-;
