1959 ES-335TD proto build
preeb
Vendor Member
Sonoran Desert
Excuse my cellphone photos above... Here are a few better photos of the guard...
The original for reference
And the one I finished making today
mrzippy
tucson az
Hey Preeb just a little off topic question. whats the best cure for static buildup after buffing the plastic.
preeb
Vendor Member
Sonoran Desert
Final sanding with 320 grit
Holly veneer is thinned down to about 0.02"
HS edges are sanded manually to round over the sharpens and to get that smooth old look.
I'll be using the strap button hole for hanging the guitar during finishing
All sanded and ready for finishing
Fingerboard is masked
Wood working stage is complete
Shepherd
Maple Ridge, Canada
Whoever designed the 335 sure had a good eye. Funny how this build seemed to go so much fast than the LP. Do you have any plans to build your own bodies?
preeb
Vendor Member
Sonoran Desert
Yeah... but remember that I had to fabricate all the 50's LP parts including the PAF's, M69's, hardware...etc.. Most of them are used on the 335 as well.
I still need to make the little cream plastic button buggers though.
preeb
Vendor Member
Sonoran Desert
Yeah a few pages back, though I can't help but wonder how great it would look dressed in cherry red...
The next proto (59 dot neck bound board) will be a dark burst (-;
I felt that the unbound 58 would be more of a typical blonde candidate...
But I'm more concerned with the tone right now. The guitar taps amazingly nice and I can't wait to plug it in (-;
preeb
Vendor Member
Sonoran Desert
Good news on the little bugger...
I got an original 58 CAB button. It is still snow white in color and smells real bad... LOL
I found a small shop here in Israel that does quick prototypes by copying the original the same way I did with the M69's (see the LP proto thread) with a silicone mold and created a 100% true copy from a special hard resin. Now... here comes the good part... They can also create a mold from the resin copy and mold CAB!!! They have some kind of a small manual machine to do them one by one.
I already gave them some raw CAB material this morning and waiting for the results.
Cross your fingers... If this doesn't work I'm stuck and will not make the part from CAB but rather use cold molding with hard white resin. No way am I going to make a steel mold and run a full batch for this part of course.
Here's the original used for making the part with a NOS #6 1" wood Nickel screw.
I've seen a few 58's that had a slotted flat head screw but I'm not sure if it's the original or an after market screw... any input would be greatly appreciated.
MRJ.
West End, NC
Me too.
First part - Dec/2012, second - Dec/2013. Sheesh!
This will only begin on the verge of the Mayan calendar end... I think
Two and a half years of anticipation. At least the Bluray Extended versions are coming out soon.
Getting back on topic, how long did Gibson use the white strap buttons?
