1956 Telecaster build
Discussion in 'Tele Home Depot' started by preeb, Jan 29, 2009.
  1. Lostheart
    Lostheart Tele-Afflicted
    Germany
    Gil, I'd give my right arm to know where you got your stepped drill bit from...was it custom made?
    Drilling ferrules is such a PITA and this would sure speed up the job!
  2. preeb
    preeb Poster Extraordinaire Vendor Member
    Sonoran Desert
    A short day today... I'll get on with the body finish and start with the pickups.
    I already have a few flatworks of Tele pu's that I cut a while back but didn't take pictures... so for the complete pu process you can check here.
    The body needs a little yellowing, just a bit so it will look like an authentic 55 blonde.
    I'll use two thin coats here, one clear and one slightly cream tinted. this way, when the guitar will get played the tint will fade first in the correct places and the aging will look as it should, this is because lacquer, in the real time line, will get darker on the outer surface.
    I start with sanding the oversprayed (little dry powder) areas left from the white blonde coat.
    The step drill is back from sharpenning... so the ferrule holes are drilled. No chips as the lacquer is still fresh and I used high speed on the drill press
    Clear aged lacquer coat
    followed by tinted coat
  3. preeb
    Sonoran Desert
    Now it looks aged enough (really bad pictures today... it looks much nicer in real life)
    Same for the back... I took the following shot before the tint so you can see the contrast between the white and the tinted sides
    tinting stage is done
  4. preeb
    Sonoran Desert
    Hanged for 24 hours. Here's a few more bad shots...
  5. preeb
    Sonoran Desert
    Now for the pickups.
    The bridge pu will be a 1955 type with raised D & G sand casted AlNiCo-3 magnets plain enamel coated AWG 42 wire. I plan to wind it to 6.1K (about 8000 wounds) which is right at the lower range for that period (I like the tone ot weaker pu's better).
    The neck pu will match the bridge with same magnets but with enamel coated AWG 43 wire. 7K (at 8000 wounds). Yes... the neck pu should have a slightly higher resistance, but it will work great, trust me. That's how it was back in the old days too.
    Flatworks and magnets are selected
    Magnets are hammered in to fit tightly in the holes
    I use this little jig to flush the magnets on the bottom flatwork.
    Spacers are attached and secured
  6. preeb
    Sonoran Desert
    Top flatwork is pressed in and spacers are removed
    I repeat the same process for the neck pu and I'm done with this step
    pu's are attached to a wire and prepared for a nitro lacquer bath
  7. preeb
    Sonoran Desert
    VVVV
  8. preeb
    Sonoran Desert
    In the bath we go... this is a very old lacquer and will give the pu a slight mojo color
    They look bad but the lacquer will get flushed and look nicer in a few hours
    I'll introduce them to the body... they are going to spend a lifetime togeather... and it will start with getting dried side by side (please tell me if I'm getting too romantic here...)
    That's it for today.
    See you soon,
    Gil
    twr102 likes this.
  9. preeb
    Sonoran Desert
    I had it custom ordered. Couldn't find any at the time. Before that, I had 2 templates, one with 3/8" and the other with 5/8" (actually 8mm) guides. Not a big deal, but it saves a little time. I have the same solution for the stepped tuner holes.
  10. wikur
    wikur Tele-Meister
    Sweden
    Great thread!
    I just read it from first to last post.
    Lots of useful info!
    Thanks for sharing!
  11. preeb
    Sonoran Desert
    Thank you!!!
    I wish....
    I build my own pu's.
  12. preeb
    Sonoran Desert
    Correct me if I'm wrong... but do I use the word "correct" correctly or should I correct it and do it in a more correct manner?
    Thanks!
  13. preeb
    Sonoran Desert
    Thanks.
    May I ask, what info did you find most useful?
    Gil
  14. allen st. john
    allen st. john Friend of Leo's
    Nice work.
    One question--why did you use koa for the skunk stripe?
    (Although it looks pretty dark and straight grained for koa...)
    On an original it would be Brazilian rosewood and I would think that a piece of that dimension--essentially a trim piece from a fretboard--would be rather inexpensive.
    best
    Allen
  15. preeb
    Sonoran Desert
    To the best of my knowledge, in the very early days maple was used for the skunk and plug followed by walnut and koa.
    In the early 50's koa was more common and in 1956 it was completely dropped in favor of walnut (much cheaper).
    I usually use koa in pre 56 models. It's a nicer wood. I don't care about costs and I use the best wood and materials I can get. The target is to build the best instruments I can.
    I never heard of Brazilian RW used for skunk stripes. Are you sure about that?
    All the best,
    Gil
  16. preeb
    Sonoran Desert
    I'll trade it towards your right arm... although I'm not sure what to use it for...
    Maybe I'll use it to turn the drill press on and off while my left hand is holding the piece and my right hand holding the lever.
  17. preeb
    Sonoran Desert
    Now seriously...
    Here's one solution (Cheap but works very well):
    get this step drill bit or similar (they're all over the place).
    You will need to do a little work on the tall bit
    3/16'' to 1/2'' Six Step Bit (3/16'', 1/4'', 5/16'', 3/8'', 7/16'', 1/2'')
    Cut the 3/16" and file the 1/4" section to 1/8".
    File half of the 5/16" section to 1/8" as well to shorten it to 1/4" (depth of the 5/16")
    Now you'll have a 1/8" lead for the already drilled 1/8" hole + 5/16" that follows 1/4" deep + 3/8".
    Now you'll need to put a collar on the 3/8" section at 1.7mm and you're done.
  18. Arlo
    Arlo Friend of Leo's
    Upta Camp
    Outstanding!
  19. Chris Clemens
    Chris Clemens Tele-Holic
    Aalsmeer (West-coast Delta of Holland)
    Niiiiccceeee! I'll keep fallowing this (without stalking ;-)!
  20. Lostheart
    Germany
    That's an interesting idea but I think custom made is the way to go. I wonder how much such a made-to-specs custom bit is but I will check into it....
    You do some magical stuff here, Gil! And now in the words of Uri "Echad Steim Schalosch" back to work, mate! ;-)
