1947 br6 amp project.
Discussion in 'Amp Central Station' started by jimi6string, Mar 10, 2014.
  1. Prairie Dawg
    Prairie Dawg Tele-Meister
    Windsor Heights, Iowa
    I had a BR6 a while ago that the wiring had been eaten by a very dead mouse. I ended up rebuilding it as a BR6-F because I like pentodes. I kept the original field coil Rola and it sounded pretty good.
  2. Wally
    Jimi, it looks as if Eugene has the most direct experience for you at this time. My Br-6 lives down outh near Austin now....and all I had to do was recap it, install the 3-wire, and do general service.
    It was not the most impressive Gibson amp I have ever owned...in stock form.
    As for that sign...yes, it was/is amusing....and to the point, right? For today's economy, though, you would need to multiply those dollar figures by perhaps 6 times to be realistic.
  3. jimi6string
    jimi6string TDPRI Member
    Fresno Ca
    I'm still shopping around for parts. I will post pics when ready to start project.
  4. eugenedunn
    eugenedunn Friend of Leo's
    Sacramento
    Most stuff is readily available from Weber VST. In fact, the parts list on the previous thread linked, has Weber part numbers on it, I believe.
    There are many cool speakers available from Weber...... as I said earlier, I chose the Weber Signature 8S because of it's low physical profile and higher headroom (resistance to farting out).
  5. jimi6string
    Fresno Ca
    Thanks Eugene. I will check the Weber site out. Hey I have a quick question. I put a new/used 5y3 in my 68 champ. I got sound for a bit and then it went out. Could a capacitor cause this to happen?Thanks for any input.
  6. eugenedunn
    Sacramento
    When you say "it went out".....does that mean the power light also is out? Any signs of tubes lit in the back?
    Check the fuse.
  7. jimi6string
    Fresno Ca
    The light does not come on. The fuse tests good. The tubes are lit. Would a bad light cause this? The sound just faded out.
  8. Wally
    Jimi, the pilot light runs off of the heater filament. IF the heater filaments in those tubes are glowing, then the circuit is functioning. You either have a bad bulb or a bad connection at that pilot light.
    Regarding the loss of sound in that amp....yes, capacitor/s can cuase exactly that 'symptom' to results in a 'dead' amp. One has to do some of that 'fun' stuff you mentioned.....testing and such..in order to find out what is going on. Lots of reasons why an amp goes silent. Does the amp hiss at all...or is it dead quiet? You could have bad tube/s, bad connections, bad resistor/s, bad speaker, bad output transformer, bad caps not providing voltage. Lots of fun, eh?
  9. Bluto
    Bluto Banned
    CA.
    +1....I bought a thashed BR-6 from Ebay and fixed it but did not like the sound, low gain and high hum, reworked it as a BR-6F and like it MUCH better...all that is required is to rewire the first tube socket and move the volume control from before the tube to after. FWIW the field coil speaker and OT were shot on mine so I replaced the coil w/ a 1K power resistor IIRC and used a repro Fender Deluxe OT mounted on the underside of the chassis (this was common practice on hifi amps back in the day)...also added a speaker jack, a 12" Cannabis Rex speaker, and built a new cabinet as the original was beyond repair.
    Anyway, would highly recommend converting from BR-6 to BR-6F and if it doesn't work for you it is easily reversible.
  10. jimi6string
    Fresno Ca
    That's really nice. Thank you all for the info, ideas, and help.
  11. Wally
    So, jimi, what progress have you made on the amp? Sometimes my projects take a while, too.
  12. jimi6string
    Fresno Ca
    Hey Wally,
    Yeah..... UM... I haven't started yet. LOL I've been dealing with life and being between jobs. No funds yet for the project. Spending time with family, playing music with friends. I did find a micro-phonic pre amp tube in that old champ amp I have. I hoping that's the problem for the intermitting sound. I'm going to be replacing the tubes in that amp pretty soon.
    As for the br-6.... Just been thinking a lot about it. There seems like like you can do so much to these amps. I just want to get it working at a very basic stage. Filter cap, ot, and speaker, and new tubes. Then just go from there. It will be a while still before I can start. The first thing I have to purchase is a decent, budget multi meter. :)
    You fellas have a good one!!!!
  13. jimi6string
    Fresno Ca
    Good news!!! I found the problem with the champ. Rotten speaker voice coil. Getting ready to order replacement soon!!!
