18V Pedals?
Discussion in 'The Stomp Box' started by ShortintheSleeve, Mar 11, 2019.
  1. ShortintheSleeve
    ShortintheSleeve TDPRI Member
    Memphis, TN
    I power my board with a 1Spot CS7, and the only spot left is for an 18V pedal. None of the pedals I have on the board right now can run at 18V, so I'm looking for options.
    Does anyone have any suggestions? I don't need another drive or fuzz pedal. I've been interested in a rotary speaker simulator or a phaser, but I don't know of any that run at 18V. Worse case scenario, I'll just fill on the board with a couple 9V pedals and use batteries, but I'd like to avoid that hassle.
  2. McGlamRock
    McGlamRock Friend of Leo's
    San Francisco, CA
    Danelectro made a "Cool Cat Chorus" in the late 90's early 00's that took 18V. It's mostly a chorus but you can get phaser type sounds out of it. Later they changed the model, so it ran on 9V. I have one of the 18V model and I really like it; very heavy though... feels like holding a brick.
    They're out of production now, but you can find used 18V models on eBay and Reverb. They're very affordable too, $30- $50 mostly
    ShortintheSleeve likes this.
  3. BorderRadio
    Phoenix, AZ
    Most Catalinbread pedals take 18v. I use a Echorec and Topanga. The Topanga is brilliant at 18v, I keep the Echorec at 9v.
    santiago53 and ShortintheSleeve like this.
  4. Art VanDelay
    Art VanDelay Tele-Holic
    Arcata
    Fulltone Deja Vibes are 18V if rotary/Univibe is what you're after
  5. Paul in Colorado
    Fort Collins, CO
    ShortintheSleeve and jddub440 like this.
  6. guitartwonk
    guitartwonk Tele-Meister
    People's Republic of Blighty
  7. 3-Chord-Genius
    Winchester, VA
    Ultimate Drive (Joyo) can run on 9V or 18V.
  8. blackguts
    blackguts Tele-Meister
    Saskatoon
    The caitlanbread semaphore was awesome at 18v
  9. gkterry
    gkterry Tele-Holic
    Left Field
    Earthquaker, the Depths (Vibe) is an awesome pedal that can run at 18V.
    BorderRadio and ShortintheSleeve like this.
  10. MrGibbly
    MrGibbly Tele-Afflicted
    SATX
    I use the same power supply for my board and I have 10 pedals running at 9v. Some are (obviously) daisy chained. My experience has been great in terms of noise, etc. if I just make sure that digital pedals and time-based effects have dedicated/isolated feeds from the CS-7. Other stuff doesn’t seem to be sensitive (OD, wah, tuner, fuzz). Once in a while I will pop over something like an OD/boost that can go 18v for more head room but it’s rare. It’s figuring out what to do with my one 12v digital pedal that’s the question...
  11. ReverendRevolver
    ReverendRevolver Tele-Holic
    Ohio (Nerk)
    You could grab one of the rechargeable 7 sisters pedals from red witch and pretend to plug it into the 18v.
  12. Finck
    Finck Tele-Afflicted
    São Paulo - Brazil
  13. ShortintheSleeve
    Memphis, TN
    Thanks for the suggestions, everyone. I'll take a look at the pedals you all mentioned as well as the 1Spot drop down converter.
    Thanks for the input.
  14. DaveKS
    DaveKS Friend of Leo's Ad Free Member
    KS
    With most boost, od, comp and EQ it’s usually fine to run more than 1 pedal on a single power tap of your supply. Most od are 5-20ma so you could easily run 5 od on one of the 9v 200ma taps of your CS7 and still not be anywhere near it’s limits.
  15. Obelisk
    Obelisk Tele-Afflicted
    NW USA
    There are quite a few pedals that run at 18v. I have a couple of compressor pedals and modulation pedals that need 18v to run. I think the Fulltone OCD sounds better when it sees 18v. More voltage helps the headroom and clarity.
    Doghouse_Riley likes this.
  16. santiago53
    santiago53 TDPRI Member
    buenos aires
    This. I run the Topanga, Adineko and Valcoder. All can handle either 9 or 18 v.
    BorderRadio likes this.
  17. ftbtx
    ftbtx Tele-Afflicted Silver Supporter
    The west side of Texas
    Almost all Pigtronix pedals run at 18V
  18. Seasicksailor
    Seasicksailor Friend of Leo's
    Bristol UK
    I use a Broadcast for the 18V slot. It's an always on situation into a Vox AC15c1. Lovely loveliness. :)
  19. Doghouse_Riley
    Doghouse_Riley Tele-Afflicted
    L.A.
    OCD is great on 18v.
  20. KC
    KC Friend of Leo's
    Missoula, Montana
    Cali 76 compressor sounds better at 18v, as does the Timmy, to my ear.
