18 Months in the Making
Discussion in 'Shock Brother's DIY Amps' started by MeanGreenBlues, Jul 21, 2009.
  1. MeanGreenBlues
    MeanGreenBlues Tele-Meister
    North Texas
    Started this way back in March of '08 and have been picking away at it piece by piece since then. Finally had the cab finished and I tolexed it late Sunday night (still have a bit of the headache from the contact cement fumes).
    And some gut shots:
    What is this...two long amp projects finished in the same month or so? Scary!
    Anyway, this is based on a BF Vibroverb AB763 but I've built in the '63 Brown VV bias-vary tremolo instead of the standard opto-isolator tremolo. I have the Weber Cali 15" ceramic for the speaker, a set of Allen/Heyboer iron, JJ preamp tubes and GZ34 rectifier with a pair of Winged C 6L6GCs.
    The blonde tolex was supplied by Gris...thank you, sir!
    Also, I've wired the ground switch as an OT impedance selector (8 or 4 ohm). The iron is setup to allow me to run it at 35W w/6L6s and 5AR4 on the 8ohm tap or 22W w/6V6s and 5U4G on the 4ohm.
    I haven't driven the amp yet and am still getting to know it sound-wise, but so far, the clean is amazing. I like it much more than the BF Twin or BF Deluxe. Has more mids to it compared to the two (but not like the Tweeds) which I attribute to the 15" in there. I'm a fan of stronger mids overall, probably due to my jazz/fusion background.
    All that's left are the back panels (ready to go but need the tolex) a more repro reverb cable that's a bit longer, and some cable clips to secure the power and reverb cable.
  2. LoveBandit
    LoveBandit Tele-Meister
    Northern Virginia - USA
    B-YOO-TI-FUL!! -LB.
  3. refin
    refin Friend of Leo's
    Florida Panhandle
    Shweeeeeet!
  4. MeanGreenBlues
    North Texas
    Thank you, fellas! I'm really glad to have a righteous BF clone in the stable finally.
    Refin, you're likely to see this same discussion 'elsewhere'. :D
  5. JohnnyCrash
    JohnnyCrash Doctor of Teleocity
    Fullerton, CA
    Nice work. Looks beautiful!
  6. rangercaster
    Knoxville TN for now
    not only a gorgeous amp, but really nice photos too !!!
  7. FenderLover
    Minnesota
    That is a georgous combination. There's something about a 15" that is just right. I'm kicking around a brown Vibrasonic idea for the same reason.
  8. marshman
    marshman Poster Extraordinaire Silver Supporter
    SE PA
    That is a seriously good-lookin' amplifier. I'm sitting on a early 70's 15" JBL (two of 'em, actually) with the intention of a project just like that one, though with only the 22 watt setup, as the speakers are only rated for 25 watts ea...I've been jonesin' a BF with a 15" er since I heard SRV used 'em, so 20+ years...
    Ok, lemme go get the drool off my chin...
  9. boozer
    boozer Tele-Meister
    Langley B.C. Canada
    lead dress is amazing!!!!
  10. Justin Belshe
    Justin Belshe TDPRI Member
    Oklahoma
    That is SO nice! Well done, sir!
  11. RomanS
    RomanS Poster Extraordinaire
    Vienna, Austria
    Wow, beautiful work!
  12. Lostheart
    Lostheart Tele-Afflicted
    Germany
    Wow, that's some neat soldering/wiring in that amp. Great job!
  13. Telenator
    Vermont
    We need sound clips!!!
    I love a blonde amp! Beautiful work there!
  14. Tele Fan
    Tele Fan Friend of Leo's
    Louisville, Ky
    That's just nice man! Good work.
  15. MeanGreenBlues
    North Texas
    Wow...thank you all!
    I'm going to try to get some clips soon.
  16. Engraver-60
    Engraver-60 Friend of Leo's
    Brentwood, TN
    Bee-uu-tee-ful!! I had an original back in the early 1970's, and toasted it. Did not know what I had, and now wishing I still had one. Mine had an original Jensen 15" Concert speaker, but I did not know how to make it cook. No one taught me, so I used it as a pre-amp into a Traynor 100 watt Bass amp head. POW! Took years to find someone to re-build it.
    Where did you obtain the authentic face plate and rear plates? Looks very fine. Great job. Green With Envy.
  17. MeanGreenBlues
    North Texas
    Thanks!
    One of the reasons it took so long was the patient eBay shopping and such. :D
    The chassis is from Marsh Amps, though. The rest from Weber, Mouser, and Antique Electronics.
