12AU7 in V2 of 5E3
Discussion in 'Amp Tech Center' started by Bones, Oct 21, 2017.
  1. Bones
    Bones Telefied Ad Free Member
    Luddite Island, NY
    Been doing some reading while waiting for new tubes to show up and one suggestion was a 12AU7 in V2, I happened to have one in my spare tube box and dropped it in. It definitely "fixed" some of the things that I wasn't enjoying with this amp. There's definitely a volume drop. There's definitely way less noise and hiss. The amp is now super quiet with no signal going through it. Before there was a lot of hiss even when nothing was plugged into it.
    The bass may be a little less flubby with my Les Paul, but this may be a bit of a placebo effect or the result of the volume drop?
    Also sounds cleaner, more headroom, which seems to suit my pedals a little better.
    I think it definitely made it a better "bedroom" amp
    Anyone else use a 12AU7 in V2?
  2. Dacious
    Dacious Poster Extraordinaire
    Godzone
    By dropping gain, you have reduced everything. If you have an original unmodded circuit, have you tried a 12AY7 in V1?. That combined with having the unused channel up a bit, is a way to reduce flub. Remember when the Deluxe was created and developed the hottest pickups it was intended for were singles. You'd be better to plug into the 2nd input to cut gain in the front-end.
  3. Bones
    Luddite Island, NY
    it came with 12Ay7 in V1 and 12AX7 in V2 it sounded OK, then it didn't it got really noisy and I thought maybe the tubes were bad as they were barely glowing, so I put in another set and while the "new" set did perk up the amp a bit, the hiss was amazingly loud.I did some poking around and re-soldered a few connections, but there was still a loud hiss. Putting the 12AU7 in V2 got rid of the hissing completely. Maybe both previous tubes were bad, but the amp is almost dead quiet now and sounds great. I have a new 12AY7 on the way, so maybe it will be fine once I load that into v2. Maybe how it is now wouldn't sound good to others, but it's the best the amp has sounded since I bought it.
  4. Dacious
    Godzone
    It's your amp, so if it sounds good to you that's all that matters. 5E3s are braappy and can be rude and farty. George Martin refused to record Lennon's because it was so noisy. If you have the original scemo with the heater leg grounded through the chassis.....
    Did you look at the cathode bypass cap? If they're soldered too close to the cathode resistor they can overheat.
  5. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
  6. Wally
    Is this an actual vintage 5E3? If so, what service has it had?
  7. Bones
    Luddite Island, NY
    Oh, I should have been more clear, this is a clone that I bought last spring. I'm still learning about it, but it was definitely a little bit of a sloppy build, but I got it for less than the price of a kit. I did lift the cathode bypass cap away from the resistor. The heater leg is grounded through the chassis and it also appears that the pots are grounded to the chassis, soldered directly onto it, with the pre-amp grounds going to the back of the "normal volume pot. In other words there's no pre-amp ground bus per se. This seems iffy to me as I don't trust that blob of solder on the chassis.
    asnarski likes this.
  8. Bones
    Luddite Island, NY
    no it's a clone, I forgot to mention that
  9. Bones
    Luddite Island, NY
  10. Dacious
    Godzone
    OK, that bolted on earthed pot is a likely candidate. I'm not a fan of star grounds but any dissimilar metals with current will corrode where they meet. I would solder a wire across the back of all pots and jacks and ground that to the chassis through solder, or a serated washer under a trans bolt.
    Ricky D. likes this.
  11. Bones
    Luddite Island, NY
    Great, thanks!
  12. D'tar
    D'tar Friend of Leo's
    WNY
    You're not the only one...:) Mine sounds good with a bunch of different compliments. This isn't mine but I think it sounds fantastic. Great recording amps!
    12ay,12au,6v6,5y3 w/attenuator
  13. robrob
    United States
  14. Bones
    Luddite Island, NY
  15. robrob
    United States
    "Can I do this and the Pre-phase inverter MV on the same amp?"
    Yes you can, they're both good mods.
  16. PhredE
    PhredE Tele-Meister
    Suburban PDX, OR
    Admittedly, it's been a while since I looked at the spec sheet(s), but as a reminder:
    I think most everyone knows the 12ax7 has high gain factor and the 12au7 is one of the lowest. One nice side benefit of the 12au7 is it has a wider freq. response. The specs call for something like 20Hz-20kHz IIRC.
    Check out related NoS tubes in the 12au7 family as well: 5814, 5963, 6189 - these can be really amazing in the right amp (preamp). In any case, it's your amp -- if it sounds good, go with it! Best of luck.
  17. DennisM
    DennisM Tele-Meister
    Nevada
    The same thing happened to my 5E3 build. Waaay to loud and obnoxious for the bedroom. Noisy, humming etc. I had the EH 12AY7 in V1 and a JJ 12AX7 in V2. The (new) JJ 12AX7 started 'frying bacon' (after only a few months) and I had nothing but a 12AT7 laying around so I put that in V2 to see if the 'frying bacon' went away. It did, and the amp sounds absolutely wonderful with the 12AT7. Now it's not a super loud, unusable beast. Great bottom end and still has that great deluxe sound...just WAY more manageable. Like you, this 5E3 amp has never sounded this good since I built it. The 12AT7 stays :)
  18. mherrcat
    mherrcat Tele-Holic
    California
    Great word, “braappy.” That’s the sound I described as “ratty” in the thread I started about Pre-PI MV wiring.
    I’m going to try the PI MV and the NFB switch in mine. The 12AU/AT swaps sound interesting, too, since the MV and NFB mods both allow the option of an “unmodified” setting.
  19. zook
    zook Friend of Leo's
    Cochise, AZ
    If it has Carbon Comp 1/2 watt plate resistors they are a source of hiss. I use 1 watt carbon film with great success.
    JD0x0 likes this.
  20. ce24
    ce24 Poster Extraordinaire
    Idahoastan
    Adding the negative feedback mod is your friend..... Cheap easy and it switches back to original with the three way switch...... Nothing not to like butt lots to love.....
    Cheers.
    Ha... just saw Rob's post...... Do this....: )
    robrob likes this.
