ping-ping-clicka
View attachment 1054668 That'll be the front, my jigsaw wandered roughing the wooden trim but the palm router should save it (hope so as the oak's now 10mm thick from 20mm and I hope to avoid having to thin another plank :/ )
I've emailed my mate the faceplate drawing I've drilled to, red circles for cuts and black for engraving, most likely in black laminate with white writing as he doesn't sound keen on stainless steel :/ failing that a friend of a friend has a diode laser at home he doesn't know how to use so I've been invited to try and set it up for him, if I took a fire extinguisher with me it can't be that hard can it?
NFB, sounds goodso when I read up on it, it seems there's a bit of uncertainty on the resistor's values, reading suggests a value between 2.6k to 6k for the 'Marshall' NFB resistor and the 15k one for the Bassman so I'll have to find a 2.6k one, and at the back there'll be an on/on switch for the bypass cap, 220uf and 2.2uf, I'm going to use a 100k pot for the mid as there's no room for a tone stack cut switch
I'm enjoying this![]()
very pretty.View attachment 1050641 View attachment 1050643
A little further on, I’ve the circuit board to cut to length next and PT to position and drill for, then I want to stretch a diylc file to the board size to mark the turret holes from then adjusting to put a couple of new turrets in too (and a bus Lane)
