12” Speaker suggestions
Discussion in 'Amp Central Station' started by schenkadere, Oct 7, 2019.
  1. schenkadere
    schenkadere Friend of Leo's
    NY
  2. Dismalhead
    Sacramento, California
    I put a WGS Reaper 30 in my Blackstar. It's the opposite of a bright speaker.
    schenkadere likes this.
  3. schenkadere
    NY
    Good or bad? Lol
  4. Dismalhead
    It was too dark while in the break-in period. Now it sings wonderfully though.
    swany likes this.
  5. homesick345
    Beirut, Lebanon
    The RWB has a sweet, vintage , Jensen TIGHT rounded Bass & Low-mids
    the C Rex doesn't - gets boomy & nervous down there
  6. Henry Mars
    Henry Mars Tele-Afflicted
    Bucks Co. PA
    I use the C.REX in a few of my amps and it sounds great after break in. Fits my style of playing nicely but it isn't the right speaker for every amp or every situation. I use a G12H30 in some of amps. I also have cabs that are loaded with different speakers that I will use with the same amps in different situations. You need to experiment.
    What is right for me isn't necessarily a fit for somebody else.
  7. scottser
    scottser Tele-Afflicted
    dublin
    a vintage 30 in an open back cab.
    Les Paul lover likes this.
  8. schenkadere
    NY
    Thanks. The CRex may be too bassy for me after listening to clips and reading.
  9. schenkadere
    NY
    The GB128 seems like a good overall choice...maybe too much on the highs. The stock speaker is a 50w in a 5w amp. Is there any advantage or disadvantage to going up or down in speaker wattage?
    Can a speaker be too efficient?
  10. CV Jee Beez
    CV Jee Beez Tele-Holic
    Duarte, CA
    What you described is nearly identical to how they describe the Eminence Private Jack. Best of luck.
  11. Pick_n_Strum
    Pick_n_Strum TDPRI Member
    Lino Lakes, MN
    My two cents are it's fun to experiment. With my blues deluxe I tried different tubes, including the 5751, in all 3 preamp positions. I ended up with a 5751 in V1, a 12ax7 in V2 and a 12AT7 in V3, the phase inverter position. My goal had been to increase headroom, make the volume sweep more useable and get rid of some of the stingy highs. It definitely helped.
    For example: You could try a 5751 in both positions but you may end up losing more gain than you had hoped - tweak to taste, basically
    Tim S likes this.
  12. schenkadere
    NY
    What do they mean by "extended highs"? trying to avoid fizz at all cost...well...reasonable cost, lol.
    CV Jee Beez likes this.
  13. homesick345
    Beirut, Lebanon
    British flavored speakers are more prone to this; with their high mids & treble particular signature
  14. MickM
    MickM Friend of Leo's Ad Free Member
    A steel guitar engagment.
    I would try it in v1 for a bit then put the 12ax7 back in and try in v2. Also you might like it in both positions.
  15. schenkadere
    NY
    JJ tubes and Private Jack on the way.
  16. CV Jee Beez
    Duarte, CA
    I'm not sure. As usual, there's conflicting info on the net. I had a Private Jack and also a GB128. My experience and a lot of the reviews I've read have this recurring theme of losing bass and some of the higher highs being rolled off. A Celestion G12-65 will also roll off some high highs and have less bass than the heavier magnet Celestions. Some Fanes will also roll of the highs but will have big bass. Hiwatt guys may be able top help because a lot of Hiwatt ownership is managing highs and brute power. Hope this helps.
  17. schenkadere
    NY
    The PJ sounds like what I'm looking for and the clips sound right, for whatever that's worth. I found one new for $83.38 after tax and shipping. Not too bad. Got the tubes from Eurotubes, just because I've always used them and they actually do have the best prices I found. I stuck with the 12AX7's. It's the original design so I figured I'd just see what some JJ's do. I assume Mike Fortin had his reasons.
    I have a feeling this will make a really good amp great. Thanks for all your help!
  18. Les Paul lover
    Les Paul lover Tele-Holic
    England
    That isnt more headroom. It's less gain.
    Sure, you'll be able to turn the knob further before it breaks up, but the volume at which it will break up will be the same and the overall gain reduced.
    That said, it works for some people, though if the aim is to get more clean volume, it will not do.
    If the amp has no choke, fitting a choke will increase the perceived headroom.
    But that's up to you to try.
    The easiest way to get more headroom is it get a really efficient speaker. Since you mentioned less highs, I would recommend a celestion V30. Very efficient, super smooth sounding and full sounding once broken in. They take for ever to break up though, so I'd recommend you buy used and save yourself some pennies along the way.
    scottser likes this.
  19. Les Paul lover
    England
    Actually, the JJ ECC83s, if that's what you've ordered, is very good at taming extra high end. Lots of people avoid it because of that, but it may well be a perfect fit in your quest. Their 6V6s are excellent too IMO.
    The PJ is meant to be an excellent speaker, I'm sure you'll end up with a great rig.
  20. schenkadere
    NY
    Not a V30 fan. Went with an Eminence Private Jack. It’s a 50w speaker in a 5w amp. I think that should be ok. This Diavlo was designed with a 50w speaker so I stuck with that as I stuck with the 12AX7 since that was the design of the amp.
