.022 or .047 cap?
Discussion in 'Tele-Technical' started by stefanhotrod, Oct 20, 2021.
  1. Zepfan
    Zepfan Doctor of Teleocity Silver Supporter
    Horn Lake, MS
    I like .022 caps for HB's and P90's, but smaller singles do best with the .047 for me.
    It's all about personal tastes and a .033 may be a good compromise.
    El Tele Lobo and stefanhotrod like this.
  2. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    Yes, but theoretically, when you take something away, what remains is shaped by what is taken away...so...?
    And even if the signal goes through the cap, can you actually hear any difference?
    stefanhotrod and bebopbrain like this.
  3. havlma1
    havlma1 Tele-Meister
    Middle of Europe
    Unless you have a no-load tone pot there is alway bit of signal going through. For this reason the cap value has some influence on the tone even when the tone pot is dimed. Just try it by yourself, try different caps and see. In my case I like 0.033 or 0.047 cap values, but it depends on the guitar and pickus, each guitar needs something different.
    stefanhotrod likes this.
  4. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    I like .047. When turning down a bit, it takes away some of the midrange and really pulls the guitar out of the mix for when I just want to strum along.
    I generally prefer the sound of a tone pot turned halfway down, there's something happening with the interaction of the cap and the resistor (the pot) that works for me.
    stefanhotrod and howardlo like this.
  5. AJBaker
    Switzerland
    With smaller caps (especially below .022), I find that you don't get much effect until the pot is turned down quite a ways, at which point the treble cut off is rather abrupt. Cool for a 60s Clapton lead tone, but I find the guitar is still too present in the mix.
    .022 and .047 both work well, but I find that strats and teles work better with 047 (or .033).
    Also, a no load pot is a no brainer for me. Gives the option of extra brightness with no downsides.
  6. takauya
    takauya Tele-Meister
    Forest
    You can't do good tone swell with a .022.
  7. Old Deaf Roadie
    Old Deaf Roadie Friend of Leo's Gold Supporter
    Goonieville, OR
    I prefer to stick with original factory schematics and parts schedules and learn how to make it work rather than modify the circuitry. It becomes too easy to have a variety of guitars that all sound similar. I would be amiss if I didn't state that I have a kit guitar I use as a test bed for wiring mods & learning new repair techniques.
  8. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    Shocker, only two pages so far :lol:
    I call the cap a tool the tone pot uses in its job. The higher the value, the faster/darker things will get as you turn the pot from about 6-0.
    It's a player preference thing, do you want a subtle tone change? I don't use the tone much so like .022 in almost everything (250Kpot). Nice thru the sweep.
    If you want it more aggressive....then .047 or even as high as .1 µF. Use some jumpers and experiment.
    And ftmp, being on 10, that cap doesn't really mean jack. Sure the electrical engineers, doctorates, purists can say it does on paper, but to the ear, or most ears if they can TELL a difference.................we are talking difference...........and does that difference really amount to anything good or bad to worry about ?? So just have to make a point, or prove there point.
    So it's (value) based on how you want the tool to work, what results do you need.
    I always say, YOUR geetar, YOUR ears!
    Happy pickin'
    stefanhotrod and voskarp like this.
  9. John_B
    John_B Tele-Meister
    I strongly agree that you try a .033 cap. This would be a simple and quick test.
    I favored big paper in oil caps forever but my ears tell me that Sprague Orange Drop caps sound just as good.
    I use an OD .033 cap with my SD '54 A5 bridge pup to give it a little more treble and an OD .068 cap with my Bootstrap Extra Crispy A3 bridge to give it a little more mid range. My alder body Tele required this and I now have the two best tones I have ever found for this alder Tele.
  10. jackal
    jackal Friend of Leo's Platinum Supporter
    mojave desert
    I like the 50s Gibson wiring with a no-load tone pot and a .01 or .015 cap.
    stefanhotrod, bebopbrain and GPoint like this.
  11. Chicago Matt
    Chicago Matt Friend of Leo's
    Woodstock
    I like .047 only because I get a big difference in tone with 1/4 turn. When performing I don't want to have to twist the knob so far. At least I think this is how it works. :)
    stefanhotrod and Gris like this.
  12. Wooly Fox
    Wooly Fox Tele-Meister
    Crowborough, United Kingdom
    Currently have a tone cap in my position 5 (neck Charlie Christian) of .033 and .022 on my tone control on Squire Fat Telecaster. I think 250K CTS pots make my guitar darker but does work well for dirt/fuzz. Tried .047 and found it too dark for my purposes. Was going to use .001 but the. Thought the tone control would be pointless when that low.
    Bridge bypasses tone control in position 1 (I use a 5 way superswitch) and that sounds amazing.
  13. EsquireOK
    EsquireOK Poster Extraordinaire
    U.S.A.
    0.022 uF – the kind that cost about a nickel – on a linear taper pot. Gives you a very gradual treble rolloff, resulting in less sensitivity to movement in the upper range of the pot. Lets you fine tune very slight treble adjustments.
  14. mjcyates
    mjcyates Tele-Holic
    Louisville, KY
    Never really paid much attention to it until I read this thread. I compared two of my teles, one had .047 the other had .022. I now know that I prefer .022. I like the taper/rolloff better.
  15. telemnemonics
    For me advising a client, I say turn the pot all the way down with .047 and tell me if you would ever use that setting.
    If that's darker than you would ever use, try a .033 or a .022 depending on how far rolled off you find useful.
    The smaller cap that shunts or passes at a higher frequency, delivers a longer sweep of usable tone settings.
    The bigger cap that shunts or passes at a lower frequency, delivers a darker tone when the pot is fully rolled back, and delivers more treble cut sooner, so the sweep is quicker and more extreme.
    Conversely, the .022 does not get as dark with the pot rolled all the way down, and is not as dark at 1/4 turn, so the settings are more gradual and less sudden.
    Take the ear test further if you find even a .022 combined with pot rolled back all the way, to be darker than you would ever use.
    I actually like a .01 better than .022 and have no use at all for a .047 that gets so dark that I can only use a very small portion of the pots range.
    Some players love the darker settings though, and need a lower frequency cap to get the darker settings.
    Believe it or not, one of my Esquires has two caps to the tone pot on the switch, and those are .01 and .001.
    With the .001 cap switched into the tone circuit, I can roll the pot all the way down and it just tames the treble a little bit, which i find more useful than any fully back setting with .022, .033 or .047.
    Then I can switch to the .01 cap with pot still all the way back and it's to me a pretty dark tone in terms of what I do with an Esquire.
    Let you ears decide how dark you might want to go with that control.
    I think though also many of us set amp to sound fairly bright and clear with neck pickup, then have trouble with the bridge pickup being "too bright".
    If that's the case, you cannot use your bridge pickup without rolling off the tone, you could choose any number of bridge pickups that would suit you better.
    Just as it's fair to say the full range of the tone pot can and should be useful, I'd say the full tone pot range of the bridge pickup can and should also be useful.
    If your guitar parts deliver settings you have no use for, that can be adjusted!
    There is simply no reason to keep using a bridge pickup you can't stand the tone of by itself!
    And there is no need to have a tone control you only like 1/3 the rotation of.
    stefanhotrod, GPoint, Ron C and 2 others like this.
  16. rstaaf
    rstaaf Tele-Afflicted Gold Supporter
    Here
    You have peaked my curiosity, gonna have to pop the control plate on one of my Partscasters, flip a dip switch and play it at .015 this weekend. :cool:
  17. pi
    pi Tele-Meister
    bay area, CA
    I like lower value caps. But this is a such a personal preference, you really need to try both and decide for yourself.
  18. kafka
    kafka Friend of Leo's
    Closer than you'd expect
    I do that on my Les Paul.
  19. KelvinS1965
    KelvinS1965 Tele-Afflicted
    Wokingham England
    I do something similar, except I use 0.015uF on the neck and 0.022uF on the bridge on my SG and Les Paul.
    I always seem to drop down one step over the typical values on my guitars as I find that it gives me a more useable roll off: I built a '61 style Strat earlier this year and put 0.022uF on the tone control, combined with a 500K pot. I have to turn it right down to make it sound dull and I often use 3-4 which I wouldn't do on a more typical 0.047uF/250K single coil set up. A couple of songs we play I turn it up to 10, but mostly its set somewhere in the middle so it gets used quite a bit.
    stefanhotrod and telemnemonics like this.
  20. Sea Devil
    Sea Devil Friend of Leo's
    Brooklyn, NY
    .047s are dangerous on stage. It's easy to overshoot a quick adjustment to the tone knob in mid-song.
