Picked up a ‘57 Custom Champ a couple weeks ago and couldn’t be happier with this thing. Sounds great fresh out of the box, but I wanted to make a few tasteful changes.
Relocated the power cable strap/clamp to a position that makes more sense (the stock position puts the power cable right up against the tube cage), switched out the speaker to a Jensen P8R reissue, changed the speaker cable to Evidence Audio Siren II (built by Fargen Custom Shop on Reverb), replaced the stock tubes with a full set of NOS RCA tubes (6V6GTA from December '62 and 5Y3GT from January '59), and relocated the labels inside the cabinet to be more period-correct.
Build quality of the Fargen cable is insane. They do great work. Couldn’t really tell a difference in tone between that and the standard cable. Just wanted something a little more beefy… the stock cable is not the best quality.
This amp, with a 12AX7, sounds nearly exact to the vintage units I’ve played. It turns it into a giant, tube driven, fuzz pedal. However, I really do like Fender’s decision to switch out the stock preamp tube to a 12AY7. It allows for more clean headroom and just enough breakup when it’s cranked, even with humbuckers. It allows this amp to be a bit more pedal friendly as well. Super chimey clean tones with just a the slightest hint of tube/speaker compression. It sounds huge, like a mini 5E3. The old tubes really brought this thing to life, much more natural sounding and even more touch sensitive and dynamic than stock.
I do prefer the Jensen over the stock Weber because of the chimey highs, its overall tonality just works for me. I did keep the Weber because the two speakers are completely different and they’re both outstanding.
I picked up 12AY7 and 12AX7 preamp tubes so I have the option to switch it out depending on the situation. Both are NOS RCA.
Overall, I’m beyond thrilled to have the Champ in my studio arsenal. They did a great job with this reissue and stayed true to the original circuit.
