¿ Issues with Janglebox MKI?
Discussion in 'The Stomp Box' started by Wpaul63, Oct 22, 2019.
  1. Wpaul63
    Wpaul63 TDPRI Member
    Here
    Hi TeleStompsters
    New member (long time lurker) with a quick question re the JangleBox MKI pedal which I bought secondhand online.
    Is it correct that the compression knob on the right hand side of the pedal kills the output if the knob is turned all the way CCW (to the left)?
    How "dark" are the Normal and Dark settings? When I select them I have the feeling that they are way too dark for a normal use (whereas the bright side is awesome indeed).
    Thank you for reading!
    Paul
  2. lefty73
    lefty73 Tele-Afflicted
    So I'm assuming you bought it, but haven't yet received it. I'm also assuming by MK1 you mean the black box version with orange (maybe it's red?) color font for "JangleBox" and the J-shaped note between the two knobs. Speaking of the knobs, on that version, there are two knobs: Gain (left) and Attack (right). The 3-position toggle is in the middle.
    The Attack knob controls the intensity of the compression. Gain simultaneously sets overall volume and amount of compression. I don't believe the Gain knob all the way counter-clockwise would essentially mute the pedal, but anything's possible I suppose. I just can't imagine why.
    For a sense of the EQ curve of "Normal" and "Dark", check out this video.
  3. artdecade
    artdecade Poster Extraordinaire
    Boggo Road
  4. Wpaul63
    Here
    Thx Lefty
    I actually do have the compressor with me.
    I do think there is an issue with the *right-hand* control. As I said, when turned all the way left (CCW) the volume is completely cut off, and I have the feeling that this shouldn't be (hence the post).
    As far as the tones of the center and left toggle positions I think that my hearing was thrown off from playing too much with the bright setting...when I selected the other settings my ears where too accustomed to the brighter position ;-)
    Paul
