NGD: Martin Custom Shop 00-18s
  • Thread starter stephent2
stephent2
Minnesota
The new Martin custom shop 00-18s is a joy to play. 00 size, 12 fret, short scale,..The light build, the wide nut and wide string spacing at the bridge and the bigger neck make for an exceptional guitar. I’ve bought a couple guitars from Ted at LA Guitar Sales over the years, he designs custom Martins w the right specs at a savings over what an individual would pay. I’m loving this guitar.
Deeve
Ballard
Great idea, taking advantage of another's ordering/build experience instead of choosing pretty wood colors/patterns (that's probably what I'd do).
Love those finger-tips.
Peace - Deeve
stephent2
Minnesota
I'm already on my third string change just for grins. It came w/ Martin MA540T Authentic, Martin's top of the line PB strings, they did sound great but stiff. Big bottom end. Must be the thick core.
I have a few sets of the old stand by, D'Addario EJ16,.. those were certainly easier to play and you could say more balanced, you could also say, lacks the bottom of the Martin Authentics. They're OK. Didn't have the sparkle and piano like sound of the Authentics.
Just slapped on a set of Martin MA540 FX "Tommy's Choice" Flex Core. I've liked this string on my 00-28, we'll see, they take a bit to settle in.
Curious to try some Monel string next. BTW, I've always just winged it changing strings on a slot head, I never had a system,.. recently ran across this video and man o' man, a great approach, makes immediate sense.
Mike Eskimo
Detroit
Wish I had seen that slothead stringing clip while I owned a bunch of old Nationals !😫
Like you I would always just wing it and/or put it off. 😂👎🏽
Great new guitar btw !(and Goodsell’s)
Chiogtr4x
Manassas Park, VA
The new Martin custom shop 00-18s is a joy to play. 00 size, 12 fret, short scale,..The light build, the wide nut and wide string spacing at the bridge and the bigger neck make for an exceptional guitar. I’ve bought a couple guitars from Ted at LA Guitar Sales over the years, he designs custom Martins w the right specs at a savings over what an individual would pay. I’m loving this guitar. View attachment 1201607View attachment 1201608
Beautiful!
I get my specs mixed up
I see the 12-fret neck, but is it the longer or shorter scale length! Thanks
stephent2
Minnesota
Beautiful!
Thanks!
It's shorter, 24.9", a full scale Martin 14 fret is 25.4"
as howardlo mentioned being a 12 or 14 fret doesn't dictate scale length. A D-18 14 fret Martin is 25.4" but a 00-18 and 000-18 is 24.9". So my neck is the same as some and shorter than others.
howardlo
Hobart, IN
Being 12 or 14 fret doesn’t really determine scale length, just where the neck joins the body which changes where the bridge is attached. Closer to the center of the lower bout, fuller sound.
stephent2
Minnesota
That looks like great guitar. Love the size and it being 12 fret with wider nut. Perfect!
The other spec that I'd never guess would make such a difference is the 2 1/4" string spacing at the bridge, makes fingerpicking easier and the neck is a bit wider at the 12 fret, w/ a bit more mass.
Chiogtr4x
Manassas Park, VA
Thanks!
Not all of them,
a 14 fret 000-18 ( a style I have my eye on) has the shorter scale. ( I have a Martin Dread, and a Blueridge OM-28 style, with the long scale)
I'd like to try the short scale too, just to feel that, on an acoustic
Boreas
Adirondack Coast, NY
You didn't mention how it smells.
Seriously, Martin "hog" guitars smell heavenly - especially ones with a hog top. Best air freshener ever - albeit not appreciated much in the bathroom...
stephent2
Minnesota
Not all of them,
yeah, I did correct my response to the fellow to give the variables,.. there are many. My initial point was simply in the big world of Martins, mine is shorter than the longest.
Freeman Keller
Washington
I like slot heads and once you learn the tricks they aren't that hard to string. Start at the outsides and work towards the center. Think about how the string leaves the hole in the tuner shaft and goes towards the nut. Cut the string off at the next post, stick it in so there is about 1/8 inch sticking thru the post, one wrap on one side of the post then the rest on the other
Didn't mean to hijack the thread.
Mike Eskimo
Detroit
The vast majority of Martins have what Gibson would call loooong scale 25.4
The vast majority of Gibson acoustics have what Martin would call short scale - 24.75 (seeing as Martin “short scale” is the already-mentioned 24.9)
All In the eye of the beholder.
To hardcore Les Paul freaks, most Telecasters have crazy narrow nuts (1 5/8”)
To a large swath of vintage Martin lovers , the measurement of almost all LP’s (1 11/16) is what they call narrow nuts.
Chiogtr4x
Manassas Park, VA
And don't call a Martin sunburst, a 'sunburst' around real Bluegrass folks!
You'll get yelled at ( at least I did!) - it's a Shadetop!
