NAD - Fender 57 Bandmaster
  • Thread starter CV Jee Beez
CV Jee Beez
Middle Earth
I saw this for sale online in Tucson. My buddy was headed there right around the time I would get funds from the sale of another amp. I asked him to get it for me and he did.
Just picked it up from my buddy last night.
It's 22 lbs. Lighter than the amp I sold and it sounds like the amp I sold (but not as loud).
Mostly what I can say is that there are no ugly sound, frequencies and I have no complaints. More exploring to be done at higher volume(s).
trandy9850
Camdenton, MO.
Are you sure about that weight?
It’s listed as weighing 45 lbs.
EDIT: My bad….I read incorrectly….you didn’t mean that it weighs 22 lbs…although I mis-read it that way…..apologies.
Axean naexA
Minnesota USA
Rainbow Guitars. My friend that lives in LA was there visiting over the holidays.
Rainbow guitars was always my favorite when I lived there between 1987 and 2003.
The only problem? The last couple of times I tried to go there in the last two years (my parents still live in Tucson) they were “appointments only” due to Covid… 🤬
CV Jee Beez
Middle Earth
Since my post, I've played loud in the house with a buddy and taken the amp to band practice.
In comparison with my buddy's Divided by 13 AMW39 (EL34 39 was amp), I preferred the Bandmaster's tone. It had more low mids and sounded fuller. Both were loud.
We put a CS Tele, R9 Les Paul, Reverend PA-1RT (semi hollow), Knaggs, and a Teye through the Bandmaster. Almost all sounded great with no change in settings. The single humbucker Teye (Zemaitis type) was overly bassy/wooly sounding.
I played the Bandmaster at practice last night with my LP and a Browne Protein Drive. It sounded good in the mix (there is another guitarist).
Last time, I used my high power twin and was at about 10 o'clock on the volume. This time, I was at midnight.
I can say that if you like a high powered twin but want something that sounds mostly the same without the massive power, The 5E7 Bandmaster is for you (and me).
SoK66
Four Corners USA
Good advice on the tube swaps but put a GZ34 in for the rectifier. Somone has put a 5U4 in it, which makes them really mushy. Vintage Tungsol 5881s or 80s era JAN Philips 6L6WGBs are great power tubes for that circuit. The reissue Tungsol 5881s would work best in a new production tube if you can find any. You'll have to re-bias. On my 5F4 Super clone (same circuit as that Bandmaster) I like a 5751 in V1 instead of the vintage spec 12AY7. A 12 AX7 is just way too much gain, you'll never find a clean tone with one.
Great find. Clapton uses two of those now instead of his former low power tweed Twins.
CV Jee Beez
Middle Earth
I went to a jam with my buddy and his boss.
What was really interesting was that his boss showed up with his new Dr. Z Z-Master 3x10 amp.
It was similar to my 57 Bandmaster reissue but here are some differences I perceived:
The Z had a more Marshally type of overdrive when pushed
The Z had less mids, low mids, and bottom
I thought the Z-master sounded good. It's just a matter of taste.
NTC
The overdrive profile is quite different probably due to the PI. Tone control operation is also very different. That is, compared to a 5F6A. A 5E7 and a 5E6 are similar, but the 5E6 Bassman should have more headroom.
