Zoom G5 hiss/noise
Discussion in 'Modeling Amps, Plugins and Apps' started by nikola, Dec 16, 2013.
  1. nikola
    nikola Tele-Meister
    108
    Dec 1, 2013
    Malaysia
    Hi all,
    Would like to get your opinion on an issue that I am having.
    Recently, my wife bought me Zoom G5 as a Christmas present and I have been fiddling around with it for the past week.
    However, I noticed a hiss/whine that became much clearer when I plugged the unit into our hifi. Initially, I was using the Yamaha THR's Aux input to get some tunes going.
    What I have also found is when I disengage the amp models of the patch, the hiss/whine goes away say about 90%.
    The Yamaha THR uses the same power outlet and does not face the same issue as it uses a 3 prong plug. The Zoom on the other hand, came supplied with a 2 prong plug.
    If anyone has experience with this issue, would really appreciate some help.
    Thanks in advance,
    nikola
  2. Frodebro
    Aug 17, 2012
    Seattle
    A bit of hiss is common with most amp sims, especially if it is a higher gain setting. The noise gate is your friend.
  3. nikola
    nikola Tele-Meister
    108
    Dec 1, 2013
    Malaysia
    Thing is, I am using the AC30 JMI sim with gain set low.
    Also, thanks for the noise gate tip because it has made a difference especially when changing the setting to Guitar In.
    Would you have experience with a power conditioner to see if it actually eliminated that noise? What about batteries?
