zit removal
Discussion in 'Tele-Technical' started by Gibson, Mar 28, 2007.
  1. Gibson
    Gibson Friend of Leo's
    Feb 13, 2007
    Just passing thru
    This may be over-optimistic...
    I have a natural wood-finish tele with a pickguard. I think it would look even better without the pickguard as the routing underneath is very clean. Short of refinishing the whole body, is there a way to effectively fill and conceal the screw holes to avoid leaving eight unsightly "pimples"?
  2. chickenpicker
    chickenpicker Friend of Leo's
    Jan 25, 2005
    Hi Gibson (now where have I heard that name?). Welcome to the forum.
    I'd be inclined to use something to inlay and decorate the area around the holes. Easiest way in this case is to drill to a set depth with a forstner bit then glue something round into the hole (like a coin).
    Or you could use wood filler, then sand it down, then decorate with waterslide decals before clearcoating.
  3. Jack Wells
    Jack Wells Doctor of Teleocity Ad Free Member
    Oct 19, 2003
    Albuquerque, USA
    I second the clear guard idea. You'd never be able to fill the holes and make it look right. And who knows .............. after some time you may want go back to the solid pickguard.
    Problem: The clear guard would have to have the same exact hole pattern as your original. You might be better off ordering a clear guard with no holes so you could drill your own using your current guard as a template.
    Here's a clear guard I made for an ASAT. The routing is pretty clean on these guitars also.
    ......[​IMG]
  4. Gibson
    Feb 13, 2007
    Just passing thru
    Not a bad idea -- and that Asat is pretty too. Thanks for the suggestion, I'll get right on it!
  5. kidA
    kidA Tele-Meister
    155
    Feb 14, 2007
    NYC, Dallas
    just wondering, where'd you get the clear material for your pickguard? I checked out stew mac and they only have acoustic clear guard material.
  6. Jack Wells
    Oct 19, 2003
    Albuquerque, USA
    You can purchase sheets of clear acrylic at Lowes and Home Depot. It's available in various thicknesses.
  7. NewOldStock
    NewOldStock Tele-Holic
    786
    Northern Minnesota
    I personally like the clear option mentioned by the guys above.
    I convert my teles to the hybrid(f-hole style) pickguards so I always have 2 screw holes to fill. When I fill holes I always use plug cutters and make plugs of the same species/grain/color as the body itself. After the finish is applied they're virtually undetectable.
    [​IMG][​IMG]
    Here's another idea bobkatstudios posted here last week-
  8. kidA
    kidA Tele-Meister
    155
    Feb 14, 2007
    NYC, Dallas
    ehhh, the screwguard isn't my fave, but to each his own.
    As for the screw fillers, can't do it, i have a sunburst quilted maple top.
    i'll stop by home depot and get on my clearguard asap, or i guess in may when i'm back home... i'm having serious tele withdrawal since i left it back home over spring break.
