Zepfan's CBG #2 build
Discussion in 'Tele Home Depot' started by Zepfan, Jul 2, 2015.
  1. Zepfan
    Zepfan Poster Extraordinaire
    Nov 30, 2013
    Horn Lake, MS
    Used a Brass 1/4" by 1&1/2" bolt for the nut and I used a 1/4"-20 x 2" steel bolt for the bridge. Added 5 nuts to the bridge bolt as spacer guides so the strings don't wander when using the trem.
    May end up installing some Floyd Rose style string retainer bars at the nut and bridge to keep the string angle where it needs to be.
  2. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    Zepfan's CBG#2 "Sprite"
    Have to wait a couple of weeks to order the 4-way switch. Real tempted to use a 3-way mini toggle I've got in my parts bin.
    Captain Nutslot agrees that this CBG should be called "Sprite", So I dub thee Sprite!
  3. oscinator
    oscinator TDPRI Member
    34
    Jun 10, 2014
    sunshine coast B.C
    Epic. I want to make a tremolo now :)
  4. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    When I get the string retainers installed and tune this thing up, I should get an idea how well it's going to work out. It has 2 springs on it and there's room for another if needed. I hope it works out.
    I'm having to wait awhile til I get paid again to buy the parts. :rolleyes:
  5. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    I goofed on the neck scarf joint. I originally was going to cut 3 inches back from the nut, but though the angle was too much and went back 3&1/2 inches. Should've left it at 3 inches, then I wouldn't have to use a string retainer bar at the nut.
  6. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    I went ahead and tuned it up to experiment with the trem and check for string angle problems. I think the string retainers is a good idea. I added another spring to the tremolo to ensure enough travel for tremolo operation. Also had to do a little reshaping on the trem arm since the base sits at an angle.
  7. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    You can see the string angle over the bridge in the last pics. so a retainer bar will help. Just hope I don't have bad issues with the strings going way out of tune when using this trem.
    I got the wiring done up except the switch and decided to hook up each pup and plug in to test them. I was pleasantly surprised, they sound pretty good, clean and bright enough. Didn't try any distortion or high gain yet, but I'm thinking they will hadle that well.
    Really wanting to get this finished so I can enjoy it frequently and annoy the wife. LOL
  8. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    Question? Need peoples input. Should this CBG have F-Holes or no F-Holes?
  9. justin72deluxe
    justin72deluxe Tele-Meister
    471
    Jul 23, 2010
    Oklahoma
    Great work! I vote 'yes' to some f holes.
    Can you post a video? I want to hear that thing.
  10. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    Thanks, 1 vote for F-Holes.
    Don't have a video camera, but if working at adding audio recording software to my computer. It will have to wait til after the Windows 10 upgrade though.
  11. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    C'mon People, I need your posts. F-holes or not?
  12. Captain Nutslot
    Captain Nutslot Friend of Leo's
    May 3, 2012
    Rochester, NY
    Dude, nice! I vote yes. A few different size circles, just like carbonation lol :)
  13. hemingway
    Mar 14, 2012
    London, UK
    F holes would look great.
  14. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    That might work better.
    3 votes yes so far.
  15. Jdelys
    Jdelys Tele-Meister Gold Supporter
    264
    Nov 3, 2010
    Missoula, Montana
    Really cool looking build. I'm interested how the P-bass pickups work out - they seem perfect for this application. Do the strings hit to back of the box between the bridge and trem? Looks close.
  16. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    Thanks.
    The strings are 3/16ths above the top back at the edge. When I put the retainer bar on, I'm thinking that the strings will be around 1/16ths from the top at the back edge.
    I'm hoping anyway.
    I'm not the first to use these style pups on a CBG, so they must work out okay. I've seen a few pics of some on CBG's, but didn't hear any sound samples. I'm anxious to find out on my own. They did sound good clean. I assumed that these pups would be more like a Jazzmaster pup than a Strat pup sound wise since they are wider. At least I'm hoping for that.
  17. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    Added sound/carbonation holes.
  18. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    After drilling the holes, I though about making a pickguard out of a Sprite can. I may do that, but I'll have to deal with the holes by the neck pickup. I'll either have to cover them up, or drill through the pickguard.
  19. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    The bridge. I glued the nuts to the wooden bridge plate with super glue to keep it in place. When I use the tremolo, the bolt/bridge turns in the nuts acting like a roller bridge.
  20. mindwave
    mindwave Tele-Meister
    449
    Sep 16, 2011
    orlando
    GREAT JOB
    you need to do a seperate HOW TO build on that TREM
    I have NEVER thought of tryng that
