Join TDPRI Today
Your Favorite Deluxe Reverb Settings?
Discussion in 'Amp Central Station' started by castpolymer, Nov 6, 2008.
Thread Status:
Not open for further replies.
  1. castpolymer
    castpolymer Poster Extraordinaire
    May 27, 2008
    Edmond, Oklahoma
    I feel like I am in a bit of rut with the settings on my DRRI. I am issuing a challenge to all Deluxe Reverb owners ( Original or Reissue ) to put up their best settings and what type of music this setting is best for. My setting are not germaine to this post, only what settings you like.
  2. jmwjjmwj
    jmwjjmwj TDPRI Member
    75
    Dec 21, 2003
    What do the Germans have to do with it?:D
  3. getbent
    getbent Telefied Ad Free Member
    jmwjjmwj, beautiful use of a reference to smokey and the bandit. post of the day.
    treble 7, mids 5, bass 8, reverb 2, volume 8
    MachineGunBlues likes this.
  5. postjob62
    postjob62 Tele-Holic
    818
    Feb 19, 2007
    FL
    Mids?
    I'm with you on the treble, volume and reverb. But if my bass goes over 2-3 while on the neck pickup I get the dreaded farts. I have the stock C12-K.
    What speaker do you have Getbent?
  6. holgaguy
    holgaguy Tele-Afflicted
    Apr 23, 2003
    Massachusetts
    How's it sound on 8? Do you have any sound clips?
  7. Chris S.
    Chris S. Asst. Admin Staff Member
    Mar 26, 2005
    Near TELE-Town (Wash. DC)
    Admin Post
    I think the best way to set the controls on ANY amp is to just turn the knobs while you listen, :idea: and keep turning them until it sounds good. :D
    That said, here's where I've found most DRs to sound best to me: Vol 7 or higher Treble 7~8 Bass 4~5 Reverb 2~3ish
    Hope it helps, CS :)
  8. getbent
    my tone king has mids... it is basically a deluxe... but, on a regular deluxe I'd go with the same basic settings to start... like chris said, then flavor to taste...
    but, I'd also add... I've had my amp get maladjusted (somebody brushes against a knob or whatever) and have the controls be way off and still sound cool... I'm convinced that I can't get a bad sound out of my imperial... my old sf deluxe was the same way... these days, I set it and forget it and make small adjustments to volume and tone on my tele....
    Best thing I ever learned here (okay, one of the best... the junior brown thing was pretty good too.)
  9. Del Pickup
    Del Pickup Poster Extraordinaire
    Mar 24, 2008
    New Zealand
    I agree with the bass and treble settings being around the mid point (tweaked to suit the room and the band you're playing with). I like a bit of reverb and the tremolo settings at 2-3 to give a bit of bloom to the notes.
    The one thing I've noticed with both my DRRI and Bassman is that they sound best with the volume controls set between 5 and 7 with the overall volume being set from the guitar - even for quiet practice where the guitar volume is down about 1 or 2. The amps seem to breath better and give a better tone (to my ears) when they're used that way.
    I compare it to washing your hands under a tap. If it's only set to dribble water over your fingers it won't do a proper job; if its full on the water pressure is probably too powerful; somewhere in the middle gives the best result.
  10. Vibrato channel
    volume: anywhere above 4
    treble: 2.5
    bass: 3
    reverb: 4
  11. Tele295
    Tele295 Poster Extraordinaire
    Mar 16, 2003
    Ventura CA
    -Germans?
    -Forget it. He's rolling
    Here's an odd one:
    Vol 6
    Tr 1
    Bs 1
    Reverb 4.5
    This is meaty, smokey tone. Loved it with a 2xP90 archtop in the center pickup position with the neck volume/tone at 10/7 and bridge volume/tone at 7/10
  12. trag-o-caster
    trag-o-caster R.I.P.
    Mar 16, 2003
    Flushing, Michigan
    For me, the treble goes no higher than 5, and the bass no higher than 3 (to avoiding farting). Volume up above 6, verb as needed. Stir and cover.
  13. cowboytwang
    cowboytwang Poster Extraordinaire
    Jul 28, 2003
    Sonoran Desert
    I have 5 Fender Deluxe's, if I set the knobs on them all the same, they sound like five completely different amps. One sounds bright, one is dark, one has more mids, one is loud, one is weak. Hey, maybe I should just run all of them at the same time!
  14. JTM45blues
    JTM45blues Tele-Afflicted
    May 14, 2003
    Iowa
    Yeah, I agree that treble needs to be down below 5. Anything above that and you risk losing a lot of hearing, and damaging your audience's hearing as well.
    Those DRRI amps have some nice tone, but they are plenty bright. I took my Tele to play through one the other day, and had to keep the treble at about 3-4, and of course continue to roll the bass back as I turned up the volume.
    When I've used one live before it was:
    Volume: 7
    Treble: 5
    Bass: 2.5
    Reverb: 3.5
    I was using my 335 both times, and I got GORGEOUS tone.
  15. jmwjjmwj
    75
    Dec 21, 2003
    I like to start with Volume:5, Bass:5, Treble:5, Reverb:2.5 and then adjust to the room (or the mic, if recording) and the guitar.
  16. jmwjjmwj
    75
    Dec 21, 2003
    :D
  17. bradpdx
    bradpdx Friend of Leo's
    Jul 16, 2006
    Portland, OR
    Treble 7, Bass 3, Volume 5 - 6, Reverb 3 - 4. Bright boost OFF (I moved it to a push-pull switch on the volume control).
    I always set the treble high so that the bridge PUP with the guitar tone all the way up is too freakin' bright. I then roll off treble from the guitar, which gives me lots of room to use the other pickup settings.
    No matter where I play, those knobs always migrate to those positions.
  18. bradpdx
    Jul 16, 2006
    Portland, OR
    Danny Gatton SR settings
    On a related note, I saw Danny Gatton play through a stock BFSR in the late '80s. Settings were:
    Bright ON
    Volume 9
    Treble 9
    Mid 8
    Bass 1
    There ya go. I'll bet you can hear THAT one on the bridge PUP...
    Albert Collins observed settings:
    Bright ON
    Volume 10
    Treble 10
    Mid 10
    Bass 1
    Heard that one, too.
  19. fenderguy
    fenderguy Tele-Meister
    310
    May 10, 2006
    cincinnati, ohio
    I use the old magic 6.. Vol 6 teb 6 bass 2 reverb 3 works 4 me.. Usually
  20. Michaell
    Michaell Tele-Holic
    985
    Oct 9, 2007
    on the bus
    depends
    there is no ideal setting
    different guitars sound different
    humbuckers will require different setings than single coils.
    what size room impacts settings
    just remember to the louder you go with the volume, cut the bass back accordingly.
    ( If I'm at 3 or 4 or more on the volume, the bass goes from 7 to 6 and so forth.....this is good advice for any combo amp )
  21. Axis29
    Axis29 Friend of Leo's Ad Free Member
    Jan 2, 2007
    Virginia, USA
    Live
    Vol: 5-8
    Treb: 7-9
    Bass: 3-5
    Rev: 2-3
    Home
    Vol: 3-4
    Treb: 6
    Bass: 9
    Rev: 3 (4 if I'm feeling surfy)
    Most of what I play is Blues based, with some Rockabilly and Rock N Roll. I like a bright cutting sound when I'm playing live because I like to be heard and in our band, that's where I fit. At home, I like a bit more mellowness and less in your faceness...
    Also play straight into the amp most times at home and through an OCD on stage... oh and I throw it all through a Carbon Copy delay when it's time for a bit of slapback.
Thread Status:
