Yamaha THR10C and pedals
Discussion in 'Modeling Amps, Plugins and Apps' started by kgardenia42, Oct 10, 2015.
  1. kgardenia42
    kgardenia42 NEW MEMBER!
    2
    Oct 10, 2015
    Hi,
    I recently picked up a Yamaha THR10C and it is great. I particularly like the "Class A" (DC 30) amp model as it has good cleans but I can get a nice breakup sound with it too on my (Baja) Tele.
    However, sometimes I'd like a bit more of a drive sound and I was thinking of getting a pedal to help with that.
    Can anyone recommend pedals they have used for this purpose? I was considering options like the Electro Harmonix Soul Food or the Joyo Ultimate Drive.
    Anyone have any experiences to report with these? or can you recommend others?
    Thanks.
    PS - are there any tricks to getting more of a drive sound with just the 10C? I'd read that ramping up the master and gain and turning down the guitar volume can be good for this.
  2. Laservampire
    Laservampire Tele-Meister
    140
    Nov 17, 2009
    The THR10C takes really well to pedals, and reacts like a real amp (even with germanium fuzz pedals!). Basically any nice overdrive will work well :)
  3. Erics
    Erics TDPRI Member
    4
    Oct 1, 2015
    Sweden
    When i play the tele the 10c is quite clean on most models. Shifting to PRS it changes. The humbuckers push it harder.
    I use a TC Spark booster and a Mooer Rumble with good results. Sounds good with both guitars. If you want to get more of the 10c's distortion without coloring the tone with an overdrive pedal, a booster like the TC Spark works.
  4. kgardenia42
    2
    Oct 10, 2015
    cool. thanks guys. Anyone tried the Electro Harmonix Soul Food with the 10C?
  5. TNO
    TNO Friend of Leo's
    Apr 25, 2003
    NC-USA
    I don't know that the Soul Food would be that good of a match. The Ultimate Drive is very good. BB V1 clones work well also.
  6. Bluesbrother777
    Bluesbrother777 TDPRI Member
    83
    Apr 25, 2015
    Baltimore
    I think you would need a pedal that sounds good with the volume low (on the pedal) so that you don't clip the input of the THR10C. I did not like any drive pedals through mine at first because I was used to using them with a tube amp and setting the volume to push the preamp a bit. Also, most of my OD/Fuzz pedals just sound better when they are opened up volume wise. That's why I mostly play straight to the yamaha or use only delay and modulation pedals with it.
  7. Erics
    Erics TDPRI Member
    4
    Oct 1, 2015
    Sweden
    You can get more drive from just the 10c with the level controll on the compressor. You have access to it through the editor.
  8. Hoodster
    Hoodster Tele-Afflicted
    Feb 3, 2007
    Oregon
    Can anyone share a screenshot of a heavier crunch setting patch using the compressor, preferably with the Class a or British blues. I'm in the same boat – upgraded from the original five to the 10C and missing some of the higher gain.
