Join TDPRI Today
Xotic AC Booster (compared to RC)?
Discussion in 'The Stomp Box' started by doveman, Oct 11, 2008.
  1. doveman
    doveman Tele-Meister
    454
    Jul 4, 2006
    I might use both ...
    I have the RC Boost and love what it does to the front end of my signal ... especially at live volumes. I understand the AC is a bit more colored but not a lot ... maybe a Vox-ish tone. I might like to use them both as options on the front end.
    Seeing that I'm pretty satisifed with the RC, what can anyone tell me about the AC? What can I expect? OK to directly compare to the RC since I have one ... will help make some sense of it all.
  2. mkern
    mkern Tele-Meister
    247
    Jun 14, 2008
    Toronto
    Have you checked out the Xotic website? They have extensive info on the "temendous trio" as well as very informative videos. I myself have an AC+ but I can't help because I've never demo'd an RC.
    The website is www.prosoundcommunications.com
  3. dalandan
    dalandan Tele-Afflicted
    Sep 15, 2008
    Jamaica
    AC =dumble inspired boost
    RC = "rig compensator" or a clean boost with active EQ
  5. romo
    romo Tele-Meister
    460
    Jan 13, 2008
    Toledo, Ohio
    I have an RC and used to have an AC. I liked the AC a lot. It is a good medium gain overdrive. Compared to the RC it has much more gain available and adds a little more compression. It colors the tone somewhat but it does not have that tube screamer mid hump thing. The EQ controls are extremely responsive just as they are on the RC. I used to use them together a lot but I have changed amplifiers and I don't use a pedal for my dirty tone anymore. I still have an RC on my board as a clean boost.
  6. romo
    romo Tele-Meister
    460
    Jan 13, 2008
    Toledo, Ohio
    I have also heard tons of explainations for the names of these pedals.
    AC = Almost Clean boost
    AC = cranked AC30 tone
    Dumble inspired is a new one, I don't think it sounds very Dumble but I can only compare it to recordings since I have never plugged into a Dumble myself.
    RC = Really Clean boost
    I don't know what the real logic is behind the naming system of these Xotic pedals.
  7. mkern
    mkern Tele-Meister
    247
    Jun 14, 2008
    Toronto
    The AC is not Dumble inspired. As I understand it, the intent was a modern Tube Screamer that was more "open"
  8. tonfarbe
    tonfarbe Tele-Holic
    992
    Jun 24, 2004
    Berlin, Yer-up
    Love my RC - sold the AC.
    The AC has lots of gain and a definite mid-hump. To me it sounded like a better Tubescreamer.
    I think the name is misleading. The AC is more an overdrive than a booster.
  9. Gilamnstr
    Gilamnstr Tele-Afflicted
    Feb 20, 2007
    Northwest AZ
    According to Xotic:
    RC = "Really Clean"
    AC = "Almost Clean"
    BB = "Bluesbreaker"
    As mkern and tonfarbe said, the AC is tubescreamer-esque, with more of a mid-hump than the others. Of the three, the AC gets the most mixed reviews. Some of it seems to be according to the amp you're using it through, some of it seems to be according to whether or not you like the mid-hump TS sound.
  10. doveman
    454
    Jul 4, 2006
    Update: I tried the Xotic RC, AC and BB together today. (I already own the RC and love that pedal). I decided to take the BB home.
    This might work. Both the RC and BB can run on the OD channel rather than in the clean channel.
    The treble and bass controls on the RC are about midway ... The RC is just a cool tone ... fattens up everything up while remaining clear.
    The BB requires added treble and bass with a higher gain but it gives a tight distortion on top of the OD. It's not metal, but I didn't need to go quite that far.
    Both pedals and the raw Brown Note signal can be balanced with the level control on these pedals. They also have active treble and bass controls along with the gain.
    Both pedals clean up really well when you back of the guitar's volume control. This is the best thing about the Xotic pedal line.
    I won't be able to test it with the band this week but my tests have gone well today. This might work!
    I have the active loop coming shortly and will run both new Digitech Hardwire Delay and Reverb units in the loop.
    I had to spend some $ but - think I'm close.
    :p
  11. dalandan
    Sep 15, 2008
    Jamaica
    well, i've read various things on the net saying that the AC has more of a dumble-inspired tone. the bb is more marshall-y while the rc is a clean boost. i read from the xotic site in the past that RC means Rig Compensator. meaning it should be able to compensate for a long line of pedals without signal degradation.
    anyway, no matter what they're supposed to be, the sound is what matters. i love the RC and BB. not the AC. but it's a choice.
  12. guit30
    guit30 Tele-Afflicted
    Dec 24, 2007
    Abington
  13. graphs
    graphs Tele-Afflicted
    Jul 10, 2007
    Toronto
    I tried the RC and the AC together today. The RC is definitely more transparent - but it also has only a negligible amount of gain and I'm looking for something that can put a little more hair on my signal.
    Tomorrow I plan to try out the Fulltone Fat Drive and maybe Subdecay Liquid Sunshine and see who wins. But right now the AC Booster is a very strong contender!
  14. dalandan
    Sep 15, 2008
    Jamaica
    the RC and AC are actually the same pedal with a few different parts inside. they follow the same schematic though. that's why they sound similar. :)
  15. graphs
    Jul 10, 2007
    Toronto
    really eh?
    i feel like the RC has just a bit too little gain and the AC just a bit too much. that's the only thing keeping me from buying the AC today... half the gain knob is unuseable. considering the only other pedal i'm interested in is out of stock everywhere in the city, i might just go for it anyway. it is a really great sounding pedal on the lower settings.
  16. 11 Gauge
    11 Gauge Doctor of Teleocity
    Mar 21, 2003
    Near BWI Int'l
    Bingo!
    The interesting thing is that neither is really a booster in the classic sense.
    They are both TS variants, with the main difference being an active EQ (Baxandall) bootstrapped off of the recovery (second) gain stage.
    The AC and RC are basically monozygotic, with only a few differences:
    -AC has one extra cap in the tone circuit
    -RC has more interstage attenuation at two points in the circuit
    -RC has a 250K drive pot instead of trad. 500K TS value in the AC
    -AC has asymmetrical diode clipping setup identical to Boss SD-1
    -RC has 3 1N14148 diodes X2 for greatly reduced clipping
    The BB is a little more interesting, circuitwise, IMO. The first two gain stages are pretty much chapter and verse TS, but the 2nd stage features "fixed" tone circuitry where a tone pot would be in a TS. The third stage is a moderate boost, and the fourth stage is the Baxandall active EQ like in the AC and RC. It has 2X 1N14148 symm. clipping w/51pF cap just like a TS, but a 1M drive pot like a Boss SD-1.
    They are really cool designs, but I'm not clear as to why they were monikered as boosts/preamps. Maybe a fear of being branded as just another TS variant, but I think it's of little consequence. I love the RC's light drive capabilities, and have been waiting for someone to package a TS variant with a circuit like that (maybe minus the active EQ). I can see how folks would fall in love with the AC or BB, as well.
