Wood... A Pickup Winder… Pickup... Tone …My experiment.
Discussion in 'Just Pickups' started by Deneb, Oct 26, 2015.
Tags:
  1. Deneb
    Deneb Tele-Afflicted Ad Free Member
    Feb 16, 2011
    Ukraine, Dnipro
    The sound of pickups is different. I needed to determine this difference. The word "Dark" can be replaced by another word. You can offer your name in the difference of sound.:);)
    You will notice the following changes.
    1. After replacing magnets, pickups began to sound brighter ( effect of adding Treble).
    2. The sound of pickups became dense.
    3. The bass sounds very clearly and dense.
    4. The output of the gauges was increased. At me on amplifiers it is a difference in turn of the knob of the Master for 7-10 minutes.
    El Tele Lobo likes this.
  2. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    The output of the pickups gives a significant change in sound in treble, and neodymium magnets add clean and density to the sound. For this reason, I did not offer magnets for sound Bright.
    You will notice the difference between neodymium magnets and ALNIKO magnets in pickups!
  3. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Here are a some shots of the pickups on my guitar № 1
    DSC09673.JPG DSC09674.JPG DSC09675.JPG DSC09677.JPG DSC09684.JPG DSC09686.JPG DSC09712.JPG DSC09679.JPG
    CFFF, Kriticaster, awasson and 4 others like this.
  4. NWinther
    NWinther Tele-Afflicted
    Jul 16, 2007
    Denmark Solbjerg.
    Ah like the Micro Coils I use :) Nice.....good looking guitar you got there!
  5. Zepfan
    Zepfan Poster Extraordinaire
    Nov 30, 2013
    Horn Lake, MS
    [​IMG]In this scheme, all you need to do is disconnect the middle pickup switch wire going to the second tone pot at the switch and attach it to the bridge pickup switch's middle lug.
    That will put the bridge on second tone and middle pickup will be volume only. That will increase the middle pickup's brightness and have more Quack for middle/neck and middle/bridge. Bridge pickup will have tone to adjust for darker tone when needed.
    El Tele Lobo and Deneb like this.
  6. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    Have you tried a series/parallel switch for these pickups yet?
  7. DHart
    DHart Friend of Leo's
    Oct 12, 2012
    Scottsdale, AZ USA
    Deneb likes this.
  8. rigatele
    rigatele Tele-Afflicted
    Apr 20, 2014
    It's rather simple actually, each switch just turns its respective pickup on or off.
    Deneb and awasson like this.
  9. DHart
    Oct 12, 2012
    Scottsdale, AZ USA
    OK. Nice, versatile way to select pickup combinations. I guess I need to consider such for one of my Strats. I would like to hear neck & bridge combined - is there great "quack" with that setting?
  10. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    So, I'll try to make! Thanks!
    Not yet, I worked only on pickups for the standard scheme!
  11. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Thank you so much!
    Of course not!!! This is not necessarily. I answered Zapfan of answer about the wiring pickups..I'm just using all three pickup trucks. It's very interesting.
  12. awasson
    awasson Friend of Leo's Gold Supporter
    Nov 18, 2010
    Vancouver
    That is the way I have the prototypes in my guitar. Front tone control is on the neck pickup, back tone control is on the bridge and the middle is not loaded by a tone control. I’m also using a 500k volume control but I think I’m using 250k tone controls. I’ll have to pop it off and check. I’ve got to restring it so I’ll do that this weekend and check the tone pots while I’m at it.
    Kriticaster, Zepfan and Deneb like this.
  13. awasson
    Nov 18, 2010
    Vancouver
    Deneb likes this.
  14. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Well, I'll upload it to Youtube now.
  15. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    awasson reminded me. I use pots of 500K-ohm
  16. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Thank you so much, awasson!!!
  17. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    I understand, you've been busy. I'm ordering a pickguard today to mount mine in my H/H Strat with 3 toggles. Middle toggle will have the series/parallel choice, so I'll find out soon enough how they do.:cool::twisted:
    awasson and Deneb like this.
  18. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Ok! We are waiting for the result...
    awasson and Zepfan like this.
  19. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    I drilled the holes under the switches in the standard pickguard one day. This is only for mini humbuckers ( cut off coil). Everything here is comfortable and does not interfere with anything. If it is useful, you can use it!
  20. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    What are the ideas for using a standard switch and mini-toggle switches? Are there any considerations?
