Wiring specs
Discussion in 'Squier Tele Forum' started by ShadowChancer, May 30, 2013.
  1. ShadowChancer
    ShadowChancer Tele-Holic
    871
    Apr 14, 2012
    Central Scotland
    Gone for this option with the upgrade (see foot note)
    Fender® USA Wiring Kit for Tele® Telecaster (CTS Pots & Oak Grigsby Switch)
    Option 2) The Fender DELTA TONE KIT This Custom mod kit comes with our Original Fender No Load Pot with fine spline solid shaft. Works like a standard 250K pot from 1-9 but "clicks" in at 10 (full clockwise) and takes the pot out of the circuit entirely. This eliminates the path to ground that exists with standard pots in the full setting. The result is increased power and brightness at the "full on" setting.
    Each Kit Includes:
    · (2)Genuine FENDER 250k CTS audio taper pots
    · FENDER 3-way switch w/black and white tip,
    · FENDER Switchcraft jack
    · 2x Foot Each of Black & White Cloth Wire .22
    · Fender USA 0.22k Capacitor
    · Fender USA Wiring Diagram Included
    Optional Upgrade: We are now able to include a MojoTone Volume Mod / Treble Bleed with this kit. These MojoTone Volume mods preserve high end frequencies and improve the taper when rolling back your volume.
    It`s a "suck it and see" situation
  2. waparker4
    Nov 9, 2011
    Philadelphia, PA
    Which did you choose?
    Look for threads on making a no-load pot out of a CTS. It is risky because you take the pot apart, but if there is a 10-15 $ difference in the 2 packages might be worth looking at
  3. ShadowChancer
    871
    Apr 14, 2012
    Central Scotland
    Pot mod
    is that the mod where you remove the last part of the track to cut it out at the end of travel ?
  4. waparker4
    Nov 9, 2011
    Philadelphia, PA
