Wiring question (4 way + coil tap push/pull)
Discussion in 'Tele-Technical' started by Jorgen83, Jun 20, 2019.
  1. Jorgen83
    Jorgen83 TDPRI Member
    Netherlands
    Wiring question for my Telecaster build:
    I'm going with a 4 way switch plus push pull for a bridge coil tap. I'm taking this wiring:
    ...and adding the push pull. But just to check if I'm doing this right: does this work?
    Hope this beautiful drawing makes sense...
  2. Teleterr
    Teleterr Friend of Leo's
    Lewes De.
    Thats ok.You can wire it as a SPST switch as well. Full , on the lug going to the 4 way , the middle lug , the tap on the other. When ON it will short out the coil section between tap and full giving just the tap.
    Jorgen83 likes this.
