Wiring Help
Discussion in 'Squier Tele Forum' started by dunner84, Aug 9, 2015.
  1. dunner84
    dunner84 Tele-Meister
    249
    Jul 15, 2014
    Victoria, bc
    Hello,
    I recently tried to help a friend wire up some new pickups with some switching options, and I have hit a snag.
    He has a lace sensor single coil in the neck and a lace sensor dually in the bridge. The way he wants it is so that the 3position switch works like a normal one: bridge, both, neck. A separate on,on,on 2pdt to switch the bridge from series HB to coil split to parallel HB.
    A push/pull pot to switch between each side of the dually when in coil split mode.
    1 tone
    1 volume.
    I can't find a schematic for this anywhere online. I thought I could figure it out, but it is only half working.
    Here is a diagram that I used for the on-on-on switch.. I am just not sure how to incorporate the push-pull to switch between the coils.
    I posted this in another part of the forum, but I am not sure it was the right place. Sorry for the double post.
    Thanks!
