I'm considering a bridge humbucker (single coil size) for my tele. If I do, I would like to keep the 3 way switch and add a mini toggle to split the humbucker. I can't seem to find a wiring diagram for that. Can someone post one up or link to one for me? Thanks,
You might try this. https://www.seymourduncan.com/forum...Humbucker-1-Volume-1-Tone-2-way-Toggle-Switch the other option would be to get a push pull pot and use it to split the bucker. The Squier '51 schematic has a push pull that split the bucker. You could wire it up that way. Check out this post, it may help you out. http://www.tdpri.com/threads/wiring-a-squier-51-help.467462/
