Wiring diagram telecaster a s1 and a 5-way
Discussion in 'Tele-Technical' started by KristianMalte, Mar 6, 2014.
  1. KristianMalte
    KristianMalte TDPRI Member
    5
    Mar 6, 2014
    Denmark
    Dear forum.
    Can anyone help me with some wiring problems. I am making parts-tele. I got the electronics from a Fender Tele Deluxe with an S-1 switch for cheap. But with a broken switch.
    I would like to make baja tele set-up but I have a 5-way switch I wanna use if possible. But it is NOT a superswich. Can I do that? There does not seem to be any wiring diagrams online.
    I would like the last option to be a bridge --> jack or at least bypass the tone.
  2. waparker4
    Nov 9, 2011
    Philadelphia, PA
    I believe you can wire a 5-way to have a series position with one redundant position.
    But you won't be able to do phase and straight to jack
    You can wire a 5-way to have a no tone position with one redundant position
    But you won't be able to do series and phase w/ the S1
    I think you need a super switch.
  3. KristianMalte
    5
    Mar 6, 2014
    Denmark
    Pictures of the switch
    Here are two pictures of the switch I would like to add.
  4. KristianMalte
    5
    Mar 6, 2014
    Denmark
    Thanks waparker4.
    Does that mean I can make the baja setup just with the 5-way instead of the normal 4-way?
