Wiring Advice Requested
Discussion in 'Squier Tele Forum' started by erix, Mar 2, 2016.
  1. erix
    erix TDPRI Member Silver Supporter
    48
    May 12, 2014
    Richland, MI
    Greetings Wiring Gurus,
    I've got a SD Alnico Pro II neck pickup that is RWRP and I'd like to install it in a guitar with a SD Jerry Donahue, one volume, one tone. I like the sound of the HoOP demos I have seen but I'm not sure how the RWRP plays into the whole thing. Does it even matter?
    My usual go-to site (Phostenix) doesn't seem to have a diagram for what I need. Can somebody suggest a wiring digram or alternative?
    Are the following combos available with only a 4-way switch?
    1. Bridge
    2. Bridge & Neck in Parallel
    3. Bridge & Neck HoOP
    4. Neck
    What about a 5-way with HoOP?
    I'd like to avoid other switches if at all possible.
    I haven't done any research (yet) on the Jerry Donahue wiring (I know there's a ton on that subject!). Is it worth the trouble?
    Thanks for any help you can give!
  2. erix
    48
    May 12, 2014
    Richland, MI
    Woops! Wrong Forum!
    Can a mod please move this to Tele-Technical?
    thanx!
