Wiring a Squier 51 Help!!
Discussion in 'Just Pickups' started by warthog, Mar 1, 2014.
  1. warthog
    warthog Tele-Meister
    Slovenia
    Not sure if this is the right forum, but I'll give it a try.
    HELP!
    I got a new DAllen P51 Humbucker to install in my 2013 Squier 51, but I have had almost no luck figuring out what goes where.
    My challenge is that the stock pup has only 3 wires and the DAllen has 4. When I installed the new pup after some trial and error, I ended up with a pretty weak sound (not out of phase, that was earlier).
    If I were to post the standard Squier Schematics and a copy of what wires do what on the DAllen pup, would someone be able to clue me in a little?
    Thanks!
    A
  2. warthog
    Slovenia
    Here is some more info...
    Bridge Pickup:
    A. South (neck/slug side): Start: Green (Ground) Finish: Black or Yellow
    B. North (bridge/screw side):
    Start: Red (Hot Output)
    Finish: White
    Note: For HS(S) guitars, on the screw-side of the pickup, in coil-tap scenarios only: White = Hot and Red Ground.
  3. warthog
    Slovenia
    Here are some stock schematics for Squier 51... and please remember, I know how to solder, but I don't understand technical wiring jargon... I do well with "red wire goes here, etc." :)
    Thank you in advance!!
  4. waparker4
    Philadelphia, PA
    Look at the wiring diagrams on d allen website. They have green to ground, red & white going to the push pull switch, and black to the volume pot / in your case the rotary switch. Check those diagrams out
  5. jcart
    jcart TDPRI Member
    western ma.
    oh rreat 51 info
    I have a new Squier 51, at first I needed help too to wire up my 51 but... I removed the control plate and replaced it with a std Tele plate/controls so as to have pup switching through the std Tele switch and a tone control. I have replaced the bridge pup with a SD 59 and the neck with a Stew Mac Antiquity series ..I routed out the body and clearanced the pickguard to allow the Tele plate to fit..by looking at the diagram shown..and a std diagram for a Tele I was able to figure out how to use the origional volume pot and coil split the 59...while adding a tone pot as well..
