Will a pushed-in dome affect the sound?
Discussion in 'Amp Tech Center' started by Charlie Bernstein, May 25, 2019.
  1. Charlie Bernstein
    Augusta, Maine
    Hey!
    In the process of coaxing a Ragin' Cagun out of a Pro Junior, I pushed in the dome. Will it change
    the sound?
    And is there a way to pull the dome back into shape without damaging it more?
    Thanks!
  2. FenderLover
    FenderLover Friend of Leo's
    Minnesota
    Is there a tape sticky enough that could stick and pull it out?
  3. Jonp
    Jonp TDPRI Member
    Europe
    You could try the good old vacuüm cleaner trick.
  4. schmee
    schmee Poster Extraordinaire
    Thos big screen domes will do that. Take a sharp pin and stick the tip carefully in the dome, pry the dome out. The tiny hole will disappear. You may have to do this a couple places. Will it stay out though? maybe. Screen domes or "H" domes tame the ultra highs a bit.
    Charlie Bernstein likes this.
  5. Dennyf
    Dennyf Tele-Afflicted
    Charlotte, NC
    All I can add is that I've had a few speakers with bent domes, and they still seemed to work fine. My guess is that it may affect the dispersal of high frequencies if you were into measuring such minutia.
    GFrank and Charlie Bernstein like this.
  6. Keefsdad
    Keefsdad Tele-Meister
    Toronto Canada
    I don't believe it will affect the sound. I have had a couple of spkrs like this and they sounded fine.
  7. Charlie Bernstein
    Augusta, Maine
    The vacuum cleaner worked! Thank you thank you thank you!
  8. Blue Bill
    Be careful with vacuum cleaners, things can go wrong in an instant. I've had luck putting a thick sock or two over the end of the vacuum hose, to prevent a tight seal that could wreck the cone in a flash.
    Tape usually works. Start with scotch tape or electrical tape, something not too aggressive. Duct tape is the last resort, but watch it, it can stick to the cone savagely enough to damage it. Wrap a loop of tape, sticky side out, around a finger and take your time, gently working the dome back into shape.
    On the other hand, It really does not affect the sound or performance of the speaker. The dome is mostly to keep dust out of the voice coil.
    Edit: I have to learn to type faster! Looks like you fixed it while I was writing. :)
    robrob, schmee and Charlie Bernstein like this.
  9. Charlie Bernstein
    Augusta, Maine
    The sock idea is a good one. Wish I'd done it!
    The vacuum hose was a little dirty and left a ring. The dirt cleaned right off, but that's a step I could've skipped if I'd thought of using a sock (or cleaning the hose).
    Next time . . . .
    Blue Bill likes this.
  10. muscmp
    muscmp Tele-Afflicted
    california
    wow, that's the second one today!
    i've done the pin trick and it worked fine. i was too paranoid to do the vacuum but i can see it might be safer with the sock.
    play music!
  11. whoanelly15
    whoanelly15 Tele-Holic
    Glad the vacuum worked. It didn’t for me. The glue one intrigues me, but I didn’t have the guts.
    Needle worked really well.
  12. mgreene
    mgreene Tele-Holic
    south carolina
    1st - I have a pair of 8" studio monitors and one has a pushed in dome, amazingly it doesnt seem to affect the sound at all.
    2nd - I tried the pin trick sometime back and the plastic dome was too thick/hard to be popped out by a pin.
    Maybe I will try the vac and sock. Good tips.
