Will a Celestion Gold fit in an AC15c1?
Discussion in 'Amp Central Station' started by KC, Aug 9, 2018.
  1. KC
    KC Friend of Leo's
    Mar 16, 2003
    Missoula, Montana
    I've got a Gold and I've got an AC15 but -- before I get out the soldering iron and screw gun -- I'm wondering if the speaker will clear the tubes. It sure looks like it won't. But it seems like it's been done. Does the bell cover come off?
  2. spauldingrules
    spauldingrules Tele-Holic
    904
    Dec 8, 2006
    Kansas City
  3. uriah1
    uriah1 Doctor of Teleocity Silver Supporter
    Feb 12, 2011
    Around
    Bell cover does not come off..tried..many times..lol
  4. gusfinley
    gusfinley Tele-Meister
    338
    Jun 11, 2014
    SLC, UT
    Which model? There are a lot of AC15 variants these days.
  5. gwjensen
    gwjensen Friend of Leo's
    Pretty sure it does. There's a screw under the stick on label. You should be able to feel it and just punch a quarter into the slot and unscrew it.
    MickM likes this.
  6. Shango66
    Shango66 Friend of Leo's
    Aug 15, 2012
    I tried the mount the blue from an UK made ac 30 into a recent greenbacked ac15. Wasted a few hours as it wouldn’t fit.
  7. uriah1
    Feb 12, 2011
    Around
    Try new alnico flavored neo
  8. gusfinley
    338
    Jun 11, 2014
    SLC, UT
    This is odd considering that the current AC15C1X comes with a Celestion Alnico Blue. According to the Celestion website the Blue and the Gold are the same depth.
    Again, what model of AC15 are you using?
  9. drmmrr55
    drmmrr55 Tele-Meister
    325
    Aug 20, 2017
    Federal Way, Washington
    I would think it would fit, aren't they the same size as the alnico blue? I know you can get an AC15C1X with an alnico blue instead of the greenback. I assume they are the exact same amp, except for the speaker....but I have never measure the blue, or the gold, so it's just an assumption.
  10. KC
    KC Friend of Leo's
    Mar 16, 2003
    Missoula, Montana
    Mine is an AC15c1, not an X, and apparently the cabinet dimensions are slightly different -- though the spec sheet says they're the same. So who knows.
  11. Art VanDelay
    Art VanDelay Tele-Holic
    527
    May 20, 2018
    Arcata
    I read an article by Celestion that says to remove the sticker on the bell (a Phillip's head screw is underneath) and pull the bell off (there is some glue along the base).
  12. Art VanDelay
    527
    May 20, 2018
    Arcata
  13. MickM
    MickM Friend of Leo's Silver Supporter
    The cover comes off. As stated earlier a screw resides beneath the sticker. I shoehorned one into a Peavey Classic 30 extension cab....way tight fit and soon removed it.
  14. uriah1
    Feb 12, 2011
    Around
    The Phillips was seated in glue or solder. Would not budge. I am wimpy but not much. You don’t gain that much clearance anyway. Alnico cream nice too. Tad better.
  15. Shango66
    Aug 15, 2012
    I was trying to fit the blue into a recent AC15c1. Like you, I figured that since the X model is the same dimensions it would fit, bell and all. I guess the innards of the c1 and c1X must be a bit different to accomodate the blue.
  16. drmmrr55
    325
    Aug 20, 2017
    The only difference between the c1, and the c1X, is the speaker. c1 is a Celestion greenback, whereas c1X is a Celestion alnico blue. Other than that, the amps are identical. And I'm not sure, but the dimensions between the Celestion Gold, and Celestion alnico blue look pretty much the same to me...
