Wilkinson Ez-Lok Tuners
Discussion in 'Tele-Technical' started by GhostofJohnToad, Jan 31, 2007.
  1. GhostofJohnToad
    GhostofJohnToad Tele-Afflicted
    Nov 10, 2006
    Toledo, Ohio
    Anyone use these? I am trying to find some dimensions for them. What size hole do they require in the peghead, specifically. Are they more similar to Schaller or Gotoh sealed varieties.
  2. magicguitar
    magicguitar Tele-Afflicted
    Aug 23, 2006
    Fallon, Nevada
    I picked up a set for one of my tele's last year. They fit perfectly on a licenced Tele headstock. So if you're going to put them on a standard Tele, they should work.
  3. Jack Wells
    Jack Wells Doctor of Teleocity Ad Free Member
    Oct 19, 2003
    Albuquerque, USA
    Dimensions are in mm.
  4. Fendermojoman
    Fendermojoman TDPRI Member
    74
    Sep 24, 2005
    Nashville, TN
    Locking Tuners
    I haven't used the Wilkenson's but I purchased a set of the Planet Waves lockers and they are awesum!. In fact, they work and feel better than the Fender Lockers on my 50th Deluxe Strat! :p :cool: :p
  5. GhostofJohnToad
    Nov 10, 2006
    Toledo, Ohio
    Ya know I was looking at those but all the reviews I read on them were kinda so-so to bad. The Wilkinson's were cheap, like $25, so I bought 'em.
  6. LaRSin
    LaRSin TDPRI Member
    57
    Aug 10, 2007
    Pickering, Ontario.
    how do you like them ??
  7. RomanS
    RomanS Poster Extraordinaire
    Jun 21, 2006
    Vienna, Austria
    I have a set of the Wilkinson EZ-Loks on a Partscaster; they required 10mm holes (but I think, depending on which style you're choosing, there are also some models of the Wilkinson EZ-Lok for 8.5 mm vintage-sized holes).
    They work pretty well for keeping my Bigsby-equipped Tele in tune, and they seem to be well made; but they are hard to string up, with those two holes sitting at a 90° angle.
    Actually, I like the vintage-style Kluson Deluxe locking tuners I have on my other Partscaster better (just for ease of use) - these require a smaller, 8.5 mm hole.
  8. Brian blaut
    Brian blaut Friend of Leo's
    Feb 13, 2005
    SF North Bay
    http://store.guitarfetish.com/wiezlotu6inf.html
    These right? I put them on an epiphone strat copy. I think they'll work. I think they were 10mm holes. They work pretty good. Although I lost the tiny piece of paper that came with them, so I'm not exactly sure if I'm stringing em correctly.
  9. martino
    martino Tele-Holic
    654
    Aug 2, 2007
    LA CA US
    Yea I am stuck wondering how to run the strings on these EZ-LOK tuners ? ? ?
    any one have a photo or a digram on this . . .
    Thanks TDPRI at least I am not alone.
  10. martino
    martino Tele-Holic
    654
    Aug 2, 2007
    LA CA US
  11. Brendan
    Brendan Tele-Holic
    504
    Feb 21, 2004
    I've got Wilkinson locking tuners on my Italia. That sucker stays in tune after using the tremolo. I'd buy them for a partscaster project..
  12. Stratsrgood
    Stratsrgood Tele-Meister
    196
    Dec 27, 2006
    Hampshire,UK
    I've got a set of the twin hole type on a Strat, I gave up using both holes as changing strings was hard work! All I do now is use the most suitable hole for the string and have a single turn on the wound strings and a couple of turns on the plain ones, so far its always stayed in tune.
  13. Brian blaut
    Feb 13, 2005
    SF North Bay
  14. Tanya's
    Tanya's TDPRI Member
    38
    Mar 24, 2012
    Oro Valley, Arizona
    I have them on my Reverend Warhawk. They do seem to keep things in better tune, but they make string changing really challenging. Personally, I don't like them much and will likely replace them. If you wand locking tuners the Sperzels are so much better.
  15. Angierc
    Angierc Tele-Meister
    182
    Oct 23, 2009
    East Texas
    I like them a lot
    I use them almost exclusively now. I do not understand why everyone is complaining that they are hard to string. I have had much more trouble with both vintage, normal single hole, and locking Grovers than these.
    Put it through one hole, put it through the other pull it tight tune.
    that easy
    on the lower strings put in the top hole first to ease the break angle over the nut
    on the top strings go through the bottom hole first to increase the break angle.
    Simple design that really locks the strings. YMMV
  16. schnazzybo
    schnazzybo TDPRI Member
    7
    Aug 2, 2014
    West Covina, CA
    These are awful! I bought a set for a Mexican Squier Strat, and while they do work, its like learning to walk again, its so contrary to what Im used to, then the high E kept slipping. It finally stopped slipping and works fine so far, but I wont be buying them again, and Ill probably just wrap the strings as usual next time, or change them out.
  17. DavidP
    DavidP Friend of Leo's
    Mar 16, 2003
    Vancouver, BC
    +1 on what Tanya's said...
    Yeah, they were OEM on the early batches of MIK Reverends, including my Buckshot. They lock great with the two holes at 90-degrees BUT its a real PIA removing strings, particularly at a gig situation. I replaced mine with some Grover locking mini Rotomatics that were a drop-in.
  18. bender66
    Jan 18, 2010
    on my bike
    I also have em. 10 mm holes for mine on an SX double bound. They work great, but I'm in the group that thinks they're hard to string. Strings want to keep jumping over the post & whatnot. I won't be removing them.
    There are vids on yoo tube on how to string em. I'd imbed it, but don't know how to on an idiotphone.
  19. simonsp
    simonsp Friend of Leo's
    Jan 13, 2013
    England
    Just in case you haven't seen the video
  20. mikeyb
    mikeyb Tele-Meister
    338
    Aug 18, 2014
    Chicago, IL
