Whistle in bypass?
Discussion in 'Burnt Fingers DIY Effects' started by Mark the Moose, Apr 15, 2019 at 6:25 PM.
  1. Mark the Moose
    Mark the Moose Tele-Meister
    Erie, CO
    just finished an OCD and it sounds great...except...when I click the effect off (it’s true bypass) I get a whistle kind of like a digital pedal starved for power. Any bright ideas?
  2. Mark the Moose
    Erie, CO
    Update: if I place a buffer in front of the OCD the whistle is gone but I get a huge pop when I click the footswitch on and bypass.
  3. tubejockey
    tubejockey Tele-Meister
    the bozone
    rewire your stomp switch like this. Make sure you keep wires short or shielded. You are getting oscillation from an open input.
    Mark the Moose likes this.
  4. jimilee
    jimilee Tele-Holic Silver Supporter
    Chattanooga
    Got pictures of your stomp switch wiring?
  5. tubejockey
    the bozone
  6. Mark the Moose
    Erie, CO
    I'll get a pic. I've built several dozen pedals and never heard this! I'm suspicious of the switch itself.
  7. Mark the Moose
    Erie, CO
    I rewired the switch to ground the circuit board input when in bypass. Seems to have solved the problem. Is this a common issue for higher gain pedals? I’ve only built low gainers, delays and verbs and have never encountered this issue.
    zippofan likes this.
  8. Mark the Moose
    Erie, CO
    And thanks to all of you who chimed in!
  9. tubejockey
    the bozone
    High gain pedals are far more likely to have this problem due to capacitive coupling of signals forming a feedback loop. Keeping your leads short and separating input leads from output leads is important.
