Which 12" Modeling Amp (SS) has Best Clean Channel
Discussion in 'Modeling Amps, Plugins and Apps' started by Ryan Aditantra, May 30, 2017.
  1. JasonKingsX
    JasonKingsX Tele-Meister
    172
    May 15, 2017
    Austin
    If you want the clean channel for itself ok... but if you want it to use with pedals you'd better say so because some of these amps don't work well with pedals... bro.
  2. Jim Dep
    Jim Dep Friend of Leo's
    May 23, 2010
    New York
    Working with pedals also can mean how you set the pedals up with that particular modeling amp. Where you set the output level / gain can be critical with how well a pedal integrates with the modeling software. Also, whether or not you put the pedal in front of the amp or in the effects loop can vary from pedal to pedal and the rules of placement and order might be different than what you're used to in a tube or solid state amp. Best thing to do is experiment with each one, both in front of the amp and in the effects loop.
    JasonKingsX likes this.
  3. SnowStorm
    SnowStorm Tele-Meister
    193
    Sep 16, 2015
    Buffalo, NY
    Fender Champion 100. This 2x12 has a fantastic clean channel and options for other channels too.
    GrantR likes this.
