Where to install the string tree?
Discussion in 'Telecaster Discussion Forum' started by gtech, Apr 3, 2007.
  1. gtech
    gtech Friend of Leo's
    Jan 4, 2007
    Quebec, Canada
    I am still to figure out the best place to install a round spacer type string tree on a headstock, and after checking different Teles, I noticed the location varies a lot.
    They go from the 5th tuner position to the 2nd one.
    I wanted to install it in the middle of the 1st or 2nd string length on the headstock but the angle doesn't look correct, even if that the locations I used when I installed 2 string trees.
    But I will install only 1 string tree on this one.
    What's your opinion about that?
    Thanks,
    Gilles
  2. NewOldStock
    NewOldStock Tele-Holic
    786
    Northern Minnesota
    I just copied the Tele Deluxe's position when I recently did mine. No real reason, I guess.
    Things to consider on location-
    Are you a behind-the-nut bender?
    Will it interfere with any decal placement?
  3. Scotland
    Scotland Poster Extraordinaire
    Aberdeen, Scotland, Yewrup
    Have a look at "the bible" at the various ones from various years. Pick the year closest to the style of your Tele and that's where to put it.
  4. Pete Galati
    Pete Galati R.I.P.
    Mar 25, 2006
    Fender installed them across from the A tuner on a lot of guitars. I've done that a few times. A lot of people put them more or less across from the G tuner. I did that once, and it worked ok, but it was in the way for string changes.
    So I've been putting the string tree across from the D tuner, and on a spacer lately. That would probably be in the way if you want to use a decal though.
    I imagine that the farther away from the nut that you put the string tree, the stretchier the strings will be. I put a spacer under the string tree so there isn't a hard angle break over the nut
    Pete
  5. maestrovert
    maestrovert Poster Extraordinaire
    i prefer it adjacent to the G string's tuner....leaves more room for behind the nut bends....
  6. TG
    TG Doctor of Teleocity
    Wherever it goes, I use a spacer to give me the minimum string break angle over the bridge.
    And I only ever have one.
  7. gtech
    Jan 4, 2007
    Quebec, Canada
    I forgot to add that I was also looking for a practical reason to install it in one place compared to another one.
    I suppose the Tele I built should be considered more for a '62 replica than a '52 because of the '62 pickup I installed in it. But it's all in my head I suppose. I can very well imagine I built one from another year and still be happy :p
    And in '62, the string tree, which was not a spacer anymore, was more beside the A (or D) string than the G string as in the '50s.
    Thanks for the good and bad sides of the different locations. And thanks for the idea of using a spacer. I forgot that I could use one to change the string break angle :oops:
    Gilles
  8. austintele
    austintele Tele-Afflicted
    May 1, 2004
    austin, texas
    +1
  9. gtech
    Jan 4, 2007
    Quebec, Canada
    Being a converted Strat player, these things are not yet automatic... I was using something else for that. But I admit that I started to bend the strings up there from time to time. It was more like a reflex than something deliberate. I just had to do it :lol:
    So, yes. I think I should also keep this in mind...
    Gilles
  10. Ronkirn
    May 1, 2003
    Jacksonville, FL
    It ain't rocket science....
    Ron Kirn
  11. gtech
    Jan 4, 2007
    Quebec, Canada
    Just an update about the string tree.
    I decided to go the old '50s way. And at the same time it looks different than the other Teles I have.
    Gilles
