What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    Got the beauty shots done of the Craig County guitar.
    The wood is old flooring from an office building in Vinita, Oklahoma. It's laid out at 43° because that's how the town is laid out.
    The knobs are from an old movie projector from an old theater next door to the office building where I got the wood from.
    The I.T stands for Indian Territory which is what Oklahoma was known as when Vinita became a town.
    nickhofen, ejphotos, Jupiter and 23 others like this.
  2. GeoB
    GeoB Tele-Holic
    Tidewater Virginia
    A 1962 Smith Corona Galaxy portable typewriter.
  3. brandonh
    brandonh TDPRI Member
    US
    This one is not a guitar project, but it is music related. I finally got around to building a shelf for my stereo equipment. I got done with the assembly stage last night.
    I hope I can have it sanded and lay on the first coats of finish this weekend. Top shelf is for LP player, receiver next, CD player, and an open shelf for recently played records.
    Every good project needs a good sandwich to get things going. “Gimme a half Super Italian, all the way, to go. I’ll also take a half a pickle for my little girl, please.”
    Walnut, a mix of leftovers from a previous project (dining room table) and discounted boards from the sale pile at the lumberyard. All the lumber is 4/4 except the blue-painted piece at 8/4.
    First I cut out the legs from the 8/4 board, which was roughly 5.5-in wide. I wanted to maximize the board and minimize the kerf waste, so I used my Japanese saw. The heat is already hot down here—it took about 90 minutes for 3 cuts and water breaks.
    Next I flattened the 4/4 boards using planes and jointed the edges on the router table. I glued up 4 shelves at 20—in wide by 16 deep.
    After the shelves dried, I made an MDF template for the final shaping. There’s a gentle curve on the front of the shelf that matches the dining room table I made a few years ago.
    Usually for a fixed shelf I’d do dadoes, but I wanted to try something new with this project, so I opted for dowels. This is only going to hold stereo equipment, so I wasn’t too worried about weight. I used the cheap Harbor Freight dowel centering tool. It wasn’t great but wasn’t horrible, either. It was awfully fiddly transferring dowel holes to their mating pieces. I’ll probably stick with traditional joinery.
    Legs, shelves, and rails dimensioned. I knocked down the hard edges with a 3/16-inch roundover bit.
    This is a bad picture, but I used dowel centering points to mark where to drill for the rails, then went off to the drill press.
    I used my granddad’s egg beater drill to put a counterbore on the holes. I read that this helps with glue-ups somehow, something about giving the glue a little room to spill out or suchlike.
    Continued...
  4. brandonh
    US
    My back legs are 90-degrees, and my front legs are angled 4 degrees off that. Granddad’s try square. Love using his tools.
    I repeated the centering points and drilling for the front legs, only with a 4-degree tilt on the drill press table.
    And glued the front legs into the back leg/side rail assembly.
    I used dowels to glue a short, wide rail to the back of each shelf.
    I went back and forth on the best way to attach the shelves to the legs. I decided to do the job one leg assembly at a time, rather than both at once.
    My end goal with this picture was to get the dowel holes from the shelves transferred to the leg assembly. First, I needed to devise a way to keep my leg assembly in place. I drilled two boards to my bench top to act as a cleat to hold the side and top of the leg assembly square. The free leg assembly went into this cleat. Then I laid the shelves down and squared them up. I put a cleat down at each shelf (these are the scrap boards that are parallel to the bench top). Then I clamped the four stakes to act as alignment guides for the back of the shelves to meet the back of the leg assembly.
    I flipped everything over, squared up the shelves to the leg assemblies, put the dowel centers on, aligned the shelves with the cleats, carefully placed the leg assembly in position, and gave a few good whacks with a rubber mallet to punch the dowel centers home. I went down the piece doing one shelf at a time this way. After all the dowel centers were marked, I took the leg assembly to the drill press. I added the countersink by hand as before.
    Glue up stage. I had enough clamps!
    In place. The shelf is level, but the tile floor isn’t. I need to think about my options. I’ll probably just put a shim in and forget about it.
    Thanks for looking. Updates to follow.
  5. brandonh
    US
    Very nice! This is a fantastic project. I love your concept for the series.
    RogerC likes this.
  6. Ripthorn
    Ripthorn Tele-Afflicted
    Austin, TX
    Love me some walnut! Nice work.
    brandonh likes this.
  7. Moodivarius
    Moodivarius Tele-Meister
    Northwest Ontario
    Just finished all the setup on my oldest son' Partscaster.
    nickhofen, tone57, Barncaster and 2 others like this.
  8. Jake Nelson
    Jake Nelson Tele-Meister
    Bemidji, MN
    added a blackface tone stack with treb mid bass and 68k tone slope resistor. also the blackface style negative feedback loop and 4.5k, 10k power filter dropping resistors
  9. Slowtwitch
    Slowtwitch Tele-Meister
    South Africa
    The start of Build No.2!!! :D:D:D
    Telemarx and Jake Nelson like this.
  10. magicfingers99
    magicfingers99 Tele-Afflicted
    atlanta
  11. Barncaster
    Northern California
    Let’s hear it Rog! She looks spectacular!
    RogerC likes this.
  12. RogerC
    Oklamerica
    Thanks, Rob! She did sound pretty awesome, but unfortunately I don't think I'll get the chance for any recordings.
  13. Snfoilhat
    Snfoilhat Tele-Afflicted
    Oakland, CA
    I tried to find that chip on the right of the mousehole but it got away from me. Otherwise all the material routed easily. I feel like a cub scout who was given a guitar-maker's materials to build a birdhouse. I feel guilty. But here is the finished cab. The figure on the front has really pretty movement.
  14. John Nicholas
    John Nicholas Friend of Leo's
    Poughkeepsie, NY
    Very nice!!
    How are you enjoying/learning the CNC??
  15. John Nicholas
    Poughkeepsie, NY
    A few years back, I built an electric guitar for my nephew for his college graduation. His brother has just graduated, now he does not play guitar, but loves to play the ukulele! So my brother hinted that would be a great gift... of course he only mentioned this last week and the graduation is on June 22nd!! So there is no way this will be finished before then.. too much stuff going on this month.
    Since I have never built an acoustic instrument before, I purchased a kit from StewMac while they were on sale. This one is a walnut with a spruce top. Should be a real challenge!
    Of course it will need some custom touches, even if they are pretty small... maybe his initials in mother of pearl on the headstock?? Obviously I could just put one of my decals on the headstock since the name is the same!!
    Any other customization suggestions??
    Her's a quick look at the tenor kit that just arrived.
    The long wire thing are the frets!!
  16. Jim_in_PA
    Jim_in_PA Tele-Meister
    SE PA near New Hope PA
    Yesterday, I got the fretboard glued up on the neck of my first build and also cut a "paint stick" to assist with the coming finishing process for the solid body for the same build. Today, I cut another body, but for a Thinline inspired version and met with a client for some CNC work he needs done for a project.
    John Nicholas likes this.
  17. mefgames
    mefgames Tele-Afflicted Platinum Supporter
    North Bay, Ca
    When I saw the pics of this build in its early stages, I must admit, I thought it was a bit odd. Seeing the finished product, I am floored, pun intended. Excellent work !! I'd be very happy to play/own that one !!
    RogerC likes this.
  18. Doyledagain
    Doyledagain Tele-Meister
    Los Angeles
    I've been working on a new acoustic. Trying out some new tricks with an interior lining. I always loved what Lame Horse does with their sides, so I guess this is an homage. Although I doubt they're using high grade wrapping paper...
  19. I_build_my_own
    New York
    ...Initials in MOP for the headstock... I am ready when you are... :)
  20. cleanheadsteve
    cleanheadsteve Tele-Meister
    Arkansas
    hey, paper is wood too right?
