What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. LeftFinger
    LeftFinger Tele-Afflicted
    Saskatchewan
    In time for Spring
    nickhofen, Barncaster, tone57 and 2 others like this.
  2. intensely calm
    intensely calm TDPRI Member
    Well, it's not a guitar, but I use it for building guitars.
    This is my home built drum sander.
    The middle deck it adjustable, then there is the stationary top surface for basic flat scuff sanding with the drum, then there is the end disk sander.
    The disk sander table and the main sanding deck are removable to make a smaller storage footprint.
    Some recycling happening in there too, that's Toyota MR2 scissor jack stuck in there to lift the sanding deck.
  3. Captain Nutslot
    Captain Nutslot Friend of Leo's
    Rochester, NY
    This is some really old 2" thick wood from a fallen barn out here in western New York... should be good for the sinuses :D.
  4. Freeman Keller
    Freeman Keller Tele-Afflicted
  5. Captain Nutslot
    Rochester, NY
    Zepfan, Barncaster and LeftFinger like this.
  6. nosmo
    nosmo Friend of Leo's
    Lake Jackson, TX
    Where does the vacuum hook up to that?
    LeftFinger likes this.
  7. tone57
    tone57 Tele-Meister
    Atlanta / Lawrenceville
    Intensley, That is some sweet drum sander engineering.
    Yup That is a great pile of barnwood Nutslot sir!
    Well i just had to do it...
    Walnut under some sketchy clamping
    So Far So Good
    Lying on top of the single ply blackguard. Close enough for a first run.
    Didn't even bleed... much.
    Tone
  8. LeftFinger
    Saskatchewan
    you just caused a small psychic disturbance in England nutslut
    Barncaster and Captain Nutslot like this.
  9. intensely calm
    nosmo, great question, but I just squint my eyes and hold my breathe.
    Just kidding, well - partly kidding.
    There will be 3 separate vacuum points.
    The first is in place. It pulls dust when I'm using the main adjustable deck (adjustable deck has been removed in this first photo).
    It mounts over the opening in the very top, so it was an easy one to set up. just a few short screws hold it in place, so it's fast to swap.
    The next will be added to the Disc sander.
    The last will be added for use when the adjustable deck is not being used, but the top deck is.
    It will be a "V" shape collector that mounts under the upper deck and pulls dust down and away.
    Zepfan and eallen like this.
  10. eallen
    eallen Tele-Afflicted
    Getting started on an matching rear access cover route starting with an over thick piece of ambrosia maple that will have a thick walnut top.
    Since I will run it thru a planer I only need to route down a 1/4" far enough around the future cover to get at it with a flush saw. The excess thickness also allows me to not worry about being neat. Everything sent thru the planer and I think the cover is going to match up nicely[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Eric
    nickhofen, RolandG, Mbechmann and 9 others like this.
  11. Freeman Keller
    Fourteen or so coats. Getting close
    Zepfan, Mr_Q, CraigB and 5 others like this.
  12. 1bad914
    1bad914 Tele-Meister
    Michigan
    896442CA-C81D-49C2-BD8A-6BB9A82EC6F6.jpeg D468D9AB-2F4A-4507-BCAE-AD0ECD7A8130.jpeg 8941D763-D509-4F3D-A12E-3543669A7BF4.jpeg Finishing up an LP build to give to a domestic violence charity auction. Just setting the nut.
  13. TRexF16
    Tucson
    The other day I made this little square:
    Except, it isn't "square."
    So what is it? It's a specialized tool for laying out the fret slots on a Tele or Strat neck. The angle is "just so" to be smack on for scribing a fret slot.
    Should come in handy.
    Rex
  14. tone57
    tone57 Tele-Meister
    Hey! 1bad914,
    I recognize that jig in the background.
    That's a Bill Scheltema Neck Carve Jig isn't it?
    I built one a LONG time ago from his video.
    Worked great on one side. Idea and engineering were so logical, but i could not get it completely correct.
    Made a few pucks for the different carves too..
    Still in the shop i guess. I haven't noticed it in a while though.. hehe
    Super Single cutaway you've made! just great
    Tone
  15. LeftFinger
    Saskatchewan
    Stains left to right
    1 Vinegar and steel wool
    2 Vinegar , Peroxide and steel wool
    3 Vinegar , steel wool , brass , copper and peroxide
    4 Vinegar , peroxide and copper (fittings)
    5 Vinegar , peroxide and brass ( old used 30-06)
    #3 Stain on
    Roof - Oak
    Walls - Birch
    Different wood different color
  16. I_build_my_own
    New York
    Cool!!! Wait for it Stewmac will sell it soon for $145.99:D
  17. 1bad914
    Michigan
    Yes it is. I love that jig. I have it dialed in for tele necks. As you can see.
    tone57 likes this.
  18. TRexF16
    Tucson
    Oh, I bet they can keep it under 50 bucks! We'll have to keep our eye out for it to show up.
  19. GunsOfBrixton
    GunsOfBrixton Tele-Afflicted
    Rochester, NY
    Needed a foot switch for vibrato / reverb that wasn't hardwired to the box. Bought a few stomp box cases, some DPDT latching switches, stereo Jack's, LEDs , LED holders and power jacks.
    Soldered it all together (along with a bit of hot glue on the back of the LED holders) and voila
    RogerC and Barncaster like this.
  20. Mr_Q
    Mr_Q Tele-Meister
    Iowa
    Got my fret board and wire from LMI (thanks for the tip, Freeman). They shipped the wire in a loop, about 10" diameter (see photo).
    Should I still build a fret wire bender and properly radius it? Seems that it might sorta work as is.
    Also picked up one of those the ever-popular Rigid oscillating spindle sanders, I think I'll name him Ross.
    :cool:
    eallen likes this.
