What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. mux164
    mux164 Tele-Meister
    348
    Jul 28, 2013
    australia
    Nice!!! I thought blackbutt was hard enough lol, I have been using karri from bunnings(local hardware shop in Australia) $8 a metre so I can get a neck out of 75cm length
  2. Jackadder
    Jackadder Tele-Meister
    459
    Jun 12, 2014
    West Australia
    Enjoy! As for Bunnings timber, I've made a couple of necks from their figured, q-sawn Tassie Oak that turned out ok, just not a fan of the lighter coloured necks since I started using Blackwood....
    Speaking of Wandoo, which I love to do, dithered over dropping $250 on some long, clean planks of Wandoo, enough for 70 or so fretboards (yes, why the hesitation??) but finally decided to buy.... in between leaving the website to check my bank balance and make a coffee and returning with leaping, joy-filled heart some bastard had made off with them :mad::mad::mad::(:(:cry:
    mux164 likes this.
  3. Mark Grant
    Mark Grant Tele-Afflicted
    Oct 27, 2012
    Northern California
    Hand selected 50bf of prime featherweight 8/4 Alder yesterday. Stuffed 24" lengths into the work truck. Enough for about 10 bodies. Will be in the workbench very shortly...
  4. Swiftandbold72
    Swiftandbold72 TDPRI Member
    57
    Jun 10, 2017
    Plymouth
  5. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
  6. Clint Walker
    Clint Walker Tele-Meister
    310
    Jan 4, 2013
    Killeen, Texas
    Having some fun with this one...hope to have it finished up this week.
    fatcat, h2odog, RogerC and 13 others like this.
  7. RickyRicardo
    RickyRicardo Friend of Leo's
    Mar 27, 2012
    Calgary, Alberta
    Clint that's awesome! Where have you been? I was getting used to a new build every 2 or 3 days..:)
  8. Clint Walker
    310
    Jan 4, 2013
    Killeen, Texas
    Thanks Richard! Man, this heat has kept me out of the shop...hahaha...time to move the shop into the spare bedroom...The Mrs. won't be happy though...:D
  9. mkster
    mkster Tele-Afflicted
    Sep 25, 2010
    Montreal Quebec
    It almost done !
  10. mux164
    mux164 Tele-Meister
    348
    Jul 28, 2013
    australia
    Worked on the Tele today, the semi hollowbody was pissing me off, just need to route and cut the pickguard IMG_7673.JPG
    fenderchamp, darkforce and CraigB like this.
  11. mPacT
    mPacT Tele-Holic
    920
    Dec 23, 2014
    Burbank, CA
    Here is a reminder to drain your compressors air tank regularly. Otherwise you may be emergency ordering a replacement in the middle of the night!
    I use my compressor all the time, every day. It's "silent" so I can work all night without disturbing my neighbors. No sugar coating, I failed to drain the air tank often enough in the last 20 years.
    As I was airbrushing today, I noticed water on the floor below it. I thought that I had better drain the tank as it had probably built quite a bit of condensation up in the last month. I put an aluminum tray under the unit and tilted it back to loosen the tank drain screw. I saw a tiny rust spot and touched it with my finger, BOOM!!! Explosive release of rusty water condensation. So the tank has rusted through.
    A replacement tank cost about as much as a new silent compressor and needing to have a functional compressor asap, I ordered this:
    https://www.aircompressorsdirect.co...nVFgNZu4hjY4EjsjzHZcuRgy5nQ_Mwp99CxoCQsrw_wcB
    Sounds about the same as my existing compressor in the video. (EDIT: The customer service rating for this company is pretty low so be aware.)
  12. mPacT
    mPacT Tele-Holic
    920
    Dec 23, 2014
    Burbank, CA
  13. Barncaster
    Keep the compressor bits Mike. I'm sure you'Il find a suitable pressure tank amongst your travels.
    mPacT likes this.
  14. mPacT
    mPacT Tele-Holic
    920
    Dec 23, 2014
    Burbank, CA
    You bet! Especially if the compressor I replaced it with turns out to be a lemon.
  15. Barncaster
    I would think the tank could be fixed and pressure tested prior to use.
  16. Mark Grant
    Oct 27, 2012
    Northern California
    Yesterday I applied the color (shellac) on this Althea uke & glued the neck on. It's amazing that tinkering with telecasters has turned into this. 5 years ago I would have laughed if you told me I'd be building ukes. Haha. Onto nitro lacquer topcoats & Ebony bridge carving!
  17. Daniel94
    Daniel94 Tele-Meister
    144
    Oct 31, 2016
    Odessa, MO
    Beautiful work on that!! Is that a hand-rubbed or sprayed burst?
  18. Mark Grant
    Oct 27, 2012
    Northern California
    Thank you! Burst is sprayed. I've found shellac to be the least forgiving material to spray when compared to lacquer and automotive urethanes. But once you get the mixture perfect (it varies by the day) it works well. Did you build the mandolin in your profile pic?
    Daniel94 likes this.
  19. Barncaster
  20. Macrogats
    Macrogats Tele-Afflicted
    May 15, 2017
    Auckland, New Zealand
    The back of that uke looks amazing!!
