What Size Drill Bit For Neck Screw Holes?
Discussion in 'Tele-Technical' started by Sprinter, Jan 29, 2007.
  1. Sprinter
    Sprinter TDPRI Member
    29
    Mar 9, 2004
    Northwest Missouri
    I need to drill holes in my neck for the neck screws. What size drill bit do I need to use. I'm using standard Fender neck screws. Any, and all help will be greatly appreciated.
    Sprinter
  2. Jack Wells
    Jack Wells Doctor of Teleocity Ad Free Member
    Oct 19, 2003
    Albuquerque, USA
    The Duchossoir Strat book has a blueprint of a Strat neck. The holes are 0.125 in. dia X 0.875 in. deep.
  3. Sprinter
    29
    Mar 9, 2004
    Northwest Missouri
    Jwells393, thank you very much for your help.
    Sprinter
  4. Jack Wells
    Oct 19, 2003
    Albuquerque, USA
    In looking at that drawing above, keep in mind that .815 dimension to the first holes is measured from a 22 fret fingerboard overhang. On a 21 fret Telecaster neck the first holes should be 0.625 in from the end of the neck.
  5. mbr
    mbr TDPRI Member
    75
    Jul 7, 2006
    Estes Park, Co.
    I just drilled holes for my neck and used 9/64" or even 5/32. Just a little bigger than 1/8". The maple neck is very hard, so a slightly larger bit than the shank of the screw makes the screw thread easier. Also some soap on the threads.
    If you're using brass screws, thread the hole with steel screws first, then put in the brass.
  6. mellecaster
    mellecaster Former Member
    I use 9/64 also....and in addition, do Rob Ds trick of the water thin Superglue..wicked into the threads first (let dry first)..then a little beeswax on the screws.
  7. chickenpicker
    chickenpicker Friend of Leo's
    Jan 25, 2005
    ...a suitably short one!
  8. mbr
    mbr TDPRI Member
    75
    Jul 7, 2006
    Estes Park, Co.
    Right! Wrap a piece of tape around the drill bit at the depth you want the bit to cut, so it looks like a flag. Just as the flag wipes the shavings from the hole, you're deep enough.
  9. Sprinter
    29
    Mar 9, 2004
    Northwest Missouri
    Thank you, to everyone for your very helpful answers. Hopefully, this weekend I'll have my tele project up, and going. :D
    Sprinter
  10. tdowns
    tdowns Former Member
    Nov 8, 2003
    When tapping sheet metal screws into hard wood, any pilot hole that is smaller then the minor diameter of the screw, just begs for trouble. The only thing you are accomplishing with a smaller pilot hole is distressing the wood, resulting is enough torque to damage the screw. You can get by with smaller or no pilots in the soft woods, but I don't even like to do that.
    I've found that most sheet metal screws' minor diameter to major diameter ratio is 0.75. The neck mounting screw for the Tele is a #8 (0.164" dia). So, 0.164" x 0.75 = 0.123". This makes a 0.125" bit a decent choice. 9/64
    would be a good choice too.
    What I'm trying to put forth here is...If you don't have a good dial caliper or digital caliper to measure the minor diameter of the screw, 75% of the major diameter will get you in the ballpark.
    If you don't have the standard screw sizes in your head, just remember the arithmetic progression for screw sizes.
    DIA(mils) = 60 + 13N
    Where N is the screw #.
    i.e for a #10 screw, 60 + 130 =190 mils or 0.190"
  11. Buckocaster51
    Buckocaster51 Super Moderator Staff Member
    Jan 6, 2005
    Iowa USA
    Admin Post
    I LOVE this place. I just LOVE it!
  12. tdowns
    Nov 8, 2003
    Well, we just LOVE you to Bucko!!
  13. Sprinter
    29
    Mar 9, 2004
    Northwest Missouri
    I installed the neck on my Tele project guitar today. Everything went very well. Thank you, again to everyone for your help. :)
    Sprinter
  14. 0le FUZZY
    0le FUZZY Former Member
