What plugs in where ?
Discussion in 'Amp Tech Center' started by Bartholomew3, Apr 9, 2013.
  1. Bartholomew3
    Bartholomew3 Friend of Leo's
    Montreal
    Answers have been more like guesses in another section so trying here:
    TSA15H --- Here's a pic of the back panel. The speaker it came with is 8 ohm so it would take the 1 x 8 ohm plug.
    I have a vintage JBL K120 in a second enclosure which is 8 ohm and may want to gig small rooms with 2 x 12 at times.
    Since there isn't another 8 ohm female plug back there, where should I plug in the JBL ?
    Should work anywhere without doing damage - am I right ?
  2. waparker4
    Philadelphia, PA
    The way I read it the left 2 are the 4 ohm tap
    the mid 2 are the 8 ohm tap
    the right is the 16 ohm tap
    the left 2 are in a box labeled "2x8 ohm" 2x8 ohm makes 4 ohms.
    The mid 2 are in a box labeled "2x16 ohm" 2x16 ohm makes 8 ohms. See?
  3. JimmieT
    JimmieT Tele-Meister
    Seattle, WA
    Plug one into 1x4 and the other into 2x8.
  4. SamClemons
    SamClemons Poster Extraordinaire
    Jasper, TN
    Agree with JimmyT
  5. vanr
    vanr Tele-Holic
    AZ
    Yes
  6. String Tree
    String Tree Doctor of Teleocity
    Up North
    Agree.
  7. gitlvr
    gitlvr Friend of Leo's
    Northern Va.
    If your mommy and daddy never had that talk with you, I'm not sure I can help.
  8. Silverface
    Lawndale CA
    "Plug one into 1x4 and the other into 2x8."
    No.
    The two left jacks are boxed together, and are the 4 ohm tap. Either one 4 ohm speaker in the jack boxed inside the larger box, or two 8 ohm speakers - one in each jack.
    The other method *might* work, but you'd have to look at the schematic to be sure and here's a 99% chance it won't. Plugging two 8 ohm speakers into the two left jack, OTOH, WILL work.
    This was a very common way of marking outputs on amps...especially bass amps...in the '70's and 80's.
  9. Silverface
    Lawndale CA
