What kind of tuners I can fit on this old tele?
Discussion in 'Tele-Technical' started by triviani, Jun 9, 2018.
  1. triviani
    triviani Tele-Meister
    Osaka
    Hi,
    Noob question here, need a bit of help. What tuners can I use to replace the ones on this Japanese Matsumoku tele?
    Vintage style ones? Which brand? Should I measure everything or are these pretty standard in size?
    Thanks!
  2. RodeoTex
    Nueces Strip
    Fender sells something very similar.
    triviani likes this.
  3. moosie
    on the roof
    Actually no. The 70s style F tuners are oriented with the parallelogram angles going the other direction.
    triviani and nojazzhere like this.
  4. moosie
    on the roof
    But they are VERY similar to these, which I found on an old Ibanez lying around my house.
  5. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Measure the shaft thickness, and distance between centres. Probably a mini tuner would be best option. Just need to ensure they'll fit with the tuner shaft thickness.
  6. Vizcaster
    Vizcaster Friend of Leo's
    Glen Head, NY
    The most important dimension is the size of the hole in the headstock. Remove the tuners, and the bushings, and measure the hole (best way to measure a hole is with the blunt end of a drill bit until you find the right size, but they may be metric!). You also have the issue of the spacing between holes. Then at last you need to worry about the small holes for the little screws. New tuners are unlikely to use the same holes so there will be filling and re-drilling to be done.
    So, all that said, what convinced you that the tuners need to be replaced? Most times difficulty in tuning is a matter of the nut slots needing to be carefully filed and lubricated. Perhaps disassembly and lubrication of the tuners will be enough to freshen them up without replacing them.
  7. Wally
    If the neck is any good, then buy a good set of machines with a high ratio. Don’t worry about the fit. If the holes need to be enlarged, so be it...and it is assured that it will be necessary, ime. The holes in the back are to be filled with dowel and sealed with a dab of lacquer....or clear nail polish. A set of Kluson replicas would work...get better ones. That might not necessitate enlarging the hole. I like Grover rotominis with a 18-1 ratio.
    This work should be done by someone with experience if modification of the hole is needed.
  8. Tezuka27
    Tezuka27 Tele-Holic
    Eastern Iowa
    I'd put on a set of Gotoh split shaft tuners, but your mileage may vary.
    jb
  9. tessting1two
    tessting1two Tele-Meister
    Southern California
    I'd suggest looking at Hipshot tuners with the universal mounting plate so you don't have to drill any holes. They are available with or without staggered posts in locking and non-locking versions. Just be sure to measure the diameter of the post holes (hopefully they are 25/64 or 10mm).
    https://hipshotproducts.com/collections/guitar-tuning-machines/products/guitar-tuner-upgrade-kits
    hint: find what you want on the hipshot website and then go to Reverb to see if a dealer has them in stock for less money.
    triviani, Sollipsist and MrGibbly like this.
  10. Tonetele
    South Australia
    I'd normally recommend Gotoh but as @moosie shows those fender tuners come with bushes.
  11. BryMelvin
    BryMelvin Tele-Afflicted
    Arivaca AZ
    You can find replacements for these on ebay. You also can find relatively good ones from stewmac as "economy" tuners.
    People frown on trapezoid tuners but if you look close to pics on ebay you will find ones that the button screws on and have the same nylon gears as imported sealed tuners.
    Best bet is Stewmacs economy tuners or Kluson style vintage tuners which will fit with new attachment screw holes drilled.
  12. triviani
    Osaka
    Thanks all for your help.
    Sure, I’m replacing the nut first, but I wanted to take a look at the tuners as well.
    I can only find cheap tuners with that kind of screws, I’d rather not make any new holes in the headstock. I’ll check the Hipshot ones.
    Cheers
  13. Wally
    There is no reason to avoid putting good machines on a good neck even if it means putting new holes in that headstock. In my over 50 years of playing, Inhave never seen anyone staring at the back of a headstock to bemoan some minor changes as long as the machines keep a guitar in tune. Ommv......but this is not a visual but rather an aural endeavor and that is not a neck that will ever lose any value by putting good machines on it.
  14. clefe
    clefe TDPRI Member
    france
    You find these trapezoid tuners on so many cheap vintage guitars and there are so many owners willing to replace them by something more reliable, that I'm astonished that no manufacturer markets modern tuners with the same footprint and same hole diameter as these.
  15. Wally
    Ime, that style of tuning machine was the worst machine Fender ever put on a guitar...up until that point. Those Fenders from the ‘70’s are now worth money, so if they still have those tuners on them I would leave them be and sell such a guitar. If I wanted to play one of those guitars with such tuners, I would change to a better functioning machine.
  16. stratoman1
    stratoman1 Tele-Afflicted
    Virginia Beach, Va
    Why are you wanting to replace them ? I vote that if it's not broke dont fix it
    triviani and PCollen like this.
  17. Vizcaster
    Glen Head, NY
    There's a perception that quality tuners help a guitar stay in tune but my opinion is that's really only partly true, and indirectly at that. Tuners don't slip after a guitar is in tune, but they can be difficult to manipulate making it hard to get into tune in the first place. Nice sealed high-ratio geared tuners are a pleasure to use, but they actually aren't any more stable. If the existing tuners feel cheap and tight they're worth replacing, but keep in mind that even a set of Gotoh Kluson-style tuners can stick a bit and you need a bit of force to get the peg moving then it's smoother to operate. I try to crank downwards first to break them free then go up - even if the note is already flat before you start tuning.
  18. EspyHop
    EspyHop Tele-Meister
    Dayton, OH
    Sperzel drilless tuners (10mm) might work.
  19. triviani
    Osaka
    I’m pretty sure the nut is the cause of the guitar going quickly out of tune, it looks like it’s the original 42 yo nut! But the tuners feel a bit old too, so I thought to also change them.
    Sorry but I’m quite not convinced to make new holes on the headstock, specially when I’m going to do it myself. These Sperzel drilless tuners look promising.
    Cheers
  20. beagle
    beagle Friend of Leo's
    Yorkshire
    Be sure to measure the tuner spacing, some are wider than Fender spacings, meaning vintage kluson style tuners don't fit. The holes/bushings are usually vintage size 8.8mm.
