What is this channel for?
Discussion in 'Tele Home Depot' started by bidder, Jan 22, 2013.
  1. bidder
    bidder TDPRI Member
    20
    Nov 16, 2012
    on canada
    Hi all!
    I am in the process of building my first complete build and currently a bolt-on neck for an old LP copy. I am attempting to build a generic tele (if there is such an animal): ash body w/ maple neck.
    I have the body shaped and am going to route the pockets.
    My question is what is the purpose of the channel that spans the neck pocket to the neck pup? Is it required?
    It's within the red circle.
  2. bidder
    bidder TDPRI Member
    20
    Nov 16, 2012
    on canada
    here is the pic.
  3. Barncaster
    Barncaster Poster Extraordinaire
    Hey B,
    In the old days with heel adjustable truss rods, you would just pop off the pickguard and that little channel would allow you to get a screwdriver in there and fine tune the relief on your neck. Now understand that Leo or one of his folks came up with this as a time saving aid for setting up their newly designed Telecasters they were building. The very early ones had that channel formed with a chisel!
    Rob
  4. deadicated
    deadicated Tele-Holic
    875
    Aug 1, 2011
    Baltimore
    It lets you adjust the truss rod if it's heal adjustable, if yours will adjust at the headstock you don't need it. Or if you don't mind taking the neck off to adjust.
  5. bidder
    bidder TDPRI Member
    20
    Nov 16, 2012
    on canada
    Thanks for the quick replies!
    That makes sense. I am going with a Stewmac 2-way hot rod, adjustaple at the headstock.
    So.. I don't need the channel.
  6. newtwanger
    newtwanger Blackguardian. Ad Free + Supporter
    Feb 11, 2007
    Quebec, Canada
    You might want to read up on using a hotrod with the adjustment up at the neck.
    If you're making a Tele style guitar it will place the adjuster way deep compared to a single-action rod, so it will not sit where a Fender style adjuster sits. It's usually hidden under a big LP-style truss rod cover.
    I say go heel adjust and leave the channel. :)
