What is the favorite tuner pedal these days?
Discussion in 'The Stomp Box' started by schenkadere, Apr 16, 2019.
  1. schenkadere
    schenkadere Friend of Leo's
    NY
    Maybe there's something I'm not aware of. Thanks!
  2. OttoCorrect
    OttoCorrect Tele-Meister
    I’m away from tuner pedals entirely. Im just a clip on headstock guy these days. The dadario (or whatever) ones are real nice.
    nojazzhere and El Tele Lobo like this.
  3. schenkadere
    NY
    I did that too and I think I'm reverting.
  4. Matthias
    Matthias Tele-Afflicted
    Korg Pitch Black Poly. Simple, works great, and the ability to strum and see tuning on all 6 strings at once is like some crazy witchcraft.
  5. sjwieczorkow
    sjwieczorkow Tele-Holic
    Milwaukee
  6. schenkadere
    NY
    Similar to the Polytune? Curious how those 2 compare.
  7. Ian T
    Ian T Tele-Holic
    Tampa Bay
    I, too, can't use clip on live. Often there will be too much rumbling bass from the DJ or band playing that throws them off. Plus I don't like the look on stage.
    The Polytune mini is nice, being it takes less space. That said, the mini pedals don't seem to hold up. Mine is fine, but my bandmate's is already acting up, only a couple of years old. Plus, I've had 2 other mini pedals (albeit cheap Mooers) fail within a short amount of time, leaving me feeling that their toughness is compromised by the mini design.
    FWIW, I never use the "all strings at once" feature and the precision over a Boss is not really needed live, though it's nice when setting intonation at home (I use a Polytune clip on for that). I also had a Planet Waves pedal tuner that failed after a few months, and clip on Planet Waves tuners that also failed. All this has left me feeling that a good ol' Boss tuner is the way to go - bulletproof and accurate enough for live playing. I have seem some boards with TU2s that have been to hell and back still in use. Quality of electronics stuff seems to be declining and the old Boss pedals were built solid. The new ones may be too, I don't know.
  8. MilwMark
    near Arnold's
    I always, wonder, what do people think they are missing out on with pedal tuners?
    They're all good enough. After that, it's just whether you like the user interface.
    teletimetx likes this.
  9. jackal
    jackal Tele-Afflicted Gold Supporter
    mojave desert
    Good old Boss---works great, lasts a long time, maybe forever. Tried one of the 6 strings at once tuners, but if you got it perfect with all 6, when you went to individual strings, it was off. If I'm not using a boss, (or a Peterson for setting intonation) the Snark clip-on is great.
    Unionjack515 and MilwMark like this.
  10. schenkadere
    NY
    My clip ons have been hit or miss and my headstocks aren't really accomodating.
    BB likes this.
  11. nojazzhere
    Foat Wuth, Texas
    As I've said before, I quit using a pedal tuner several years ago.....I use the micro D'Addario clip on. It's accurate, unobtrusive (behind the headstock) and I can tune anywhere on stage without going back to my pedal board. AND....they're so cheap, I can carry a backup as a spare in case it craps out, although it never has. I put a tiny screw through the "clip on bracket" so I don't have to worry about it shaking off.
  12. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    Boss TU-12H for "real" tuning. Korg Pitchblack for gigs.
  13. Knowcaster
    Knowcaster Tele-Holic
    Pittsburgh, PA
    I am on my third tuner pedal, a Boss TU-3, which I think is the best of the ones I have tried for gigging. I started with a Korg Pitchblack knockoff, which was OK but started having issues. I got the Sonic Research TurboTuner next which was very precise, but I found a little hard to read in some lighting situations. Plus it took me a long time to get the hang of which way the readout revolved to show sharp vs. flat, it was not intuitive. I had all true bypass pedals on my board (including the TurboTuner) and was getting a little more treble dropoff that I wanted, so I bought the Boss tuner since it has a buffer. I also found it easier to read (it even has a way to crank up the brightness level of the display, though I have not used that feature) and the readout makes more sense to me. It seems to be plenty accurate for my purposes, but if you are doing setups or have dog hearing you may want to go with the TurboTuner or some kind of Peterson strobe tuner or something of that ilk.
    MilwMark likes this.
  14. MilwMark
    near Arnold's
    The thing I never got, to borrow @Knowcaster's nice image, is, if one has dog ears, can they actually play anything on the guitar? Because as soon as you fret a note, everything is no longer "perfect".
    lineboat and Ian T like this.
  15. KC
    KC Friend of Leo's
    Missoula, Montana
    I've been using a GoGo Horizon tuner, very easy-to-see and seems accurate enough. They showed up on Massdrop for cheap city but seems to be back up to $100 (or $70 for the more conventional shape). Solid product, as is the Korg Pitchblack at $60. I assume the Boss is good, too, as I've seen a million of them -- never owned one though. I share the view that the pedal is the way to go. Too many emergency tuneups on a crowded stage where the clip-on loses the pitch.
  16. joebloggs13
    joebloggs13 Tele-Holic
    Rome, NY
    Polytune 3.
  17. StanleyAccrington
    StanleyAccrington Tele-Meister
    York
    I still use my ancient Digitech Hardwire HT6 polytune.
    bsman and Paul in Colorado like this.
  18. teletimetx
    teletimetx Poster Extraordinaire
    Houston, TX
    I don't think there's much to miss out on either.
    I used a Boss TU-2 for 15 years, worked flawlessly, then ooops, maybe fatman cajon player stepped on it sideways, break it; who knows? it no function no mo'. lights just travel in trapped circle, maybe I take it apart and fix it one of these days. Maybe not.
    So I got the TU-3. Works fine, also. no problems. Tune up first set, takes a minute, check tuning, second set, fine. maybe I hear something, middle of a set. check it out, quick and easy. It's not rocket science.
    ...and while I'm in a grouchy mood - ok, does your clip on tuner have a mute button? do you imagine that your audience loves to hear your tuning routine?
    Because fatman cajon player? Sometimes, he also plays rhythm guitar and listening to him tune is pure torture. Takes him way too long and he still can't get it right using an expensive strobe tuner built into the soundboard...wtf?
    MilwMark and AlbertaGriff like this.
  19. d barham
    d barham Tele-Meister
    Halfway, MO
    I use the Peterson strobo tuner ap on my iPhone. It’s strictly an acoustic tuner though. Otherwise a clip on of just about any make is generally adequate.
  20. twotone60
    twotone60 Tele-Meister
    Charlottesville, va
    Mute button? How about volume knob? I use the Polytune clip-on because I'm determined to keep my pedalboard small.
