Weber Z-Matcher
Discussion in 'Amp Central Station' started by Milspec, Feb 13, 2019.
  1. Milspec
    Milspec Friend of Leo's
    Nebraska
    The concept of this device sounds good to me as I have several cabs with different ohms ratings that I would like to try out with various amp heads, but does this device work without losing a lot of output or other negative side-effects?
    I guess what really worries me is what happens if something goes wrong internally and leaves the amp facing an incompatible ohms rating? Can you really rely on such a device?
    Most of my heads are vintage Fenders running into a 4 ohm 2x12 cabinet. I also have a few clone heads that are switchable from 8 to 16 ohms output which presently run through a pine 1x12. I spent a lot of money on that 2x12 cabinet and the speakers sound great so if I was able to run everything through that same 2x12 4 ohm it would simplify a lot of things.
  2. Milspec
    Nebraska
    Must be a rarely used duck....must be a reason for that. I guess I will not chance it then.
  3. grolan1
    grolan1 Friend of Leo's
    Somewhere in the middle of the flippin country
    I've got one that I'll never sell, sometimes you just need it and it works perfectly!
    spellcaster and Dukex like this.
  4. corliss1
    Lansing, MI
    I've had one on my workbench for years. No issues.
    Dukex likes this.
  5. alathIN
    alathIN Tele-Holic
    Indiana
    My standard Weber tip: email CJ and tell him what you want, and what you want to avoid.
    He will steer you straight. They are not in the business of just selling whatever.
    First time I was in touch with CJ, he talked me into a cheaper speaker based on what I said I wanted. He was right.
    Milspec, Alex W and Dukex like this.
  6. archetype
    archetype Fiend of Leo's Silver Supporter
    Williamsville NY
    What @alathIN said. CJ has always provided me with the best advice on Weber products. He will recommend what you actually need and not upsell you. Expect a very concise reply, as he's a busy guy.
    Milspec and Dukex like this.
  7. Dukex
    Dukex Tele-Holic
    SoCal
    Weber = quality. There is not a piece of equipment ever made that can't fail. Yes, call C.J. and discuss. I've had one for a few years and, like grolan1, will never sell it.
  8. 24 track
    kamloops bc
    a friend of mine has a Weber Mass attenuator (a proto type) its not as pretty as the comercial units but its built like a tank a serious tank and works really well
    instead of using an 8 OHM resister it uses a mass speaker driver , there not much to these units but what is there is serious stuff
    867e65f705f33102256f35a4f9f1771f.gif IMG_0877.JPG IMG_0871.JPG IMG_0878.JPG IMG_0876.JPG
    Milspec likes this.
  9. Alex W
    Alex W Friend of Leo's
    In my tube amp coccoon.
    I have a Weber Z matcher and it works great. I have not noticed any change in output.
  10. wrathfuldeity
    wrathfuldeity Tele-Afflicted
    Turdcaster, WA
    Also have a Weber Z matcher...works great, no issues and will never sell. Its an indispensable little tool for my stable of spkrs/cabs.
    Milspec likes this.
