Weber 5f2h mod
Discussion in 'Shock Brother's DIY Amps' started by fensterman, Feb 23, 2017.
  1. fensterman
    fensterman Tele-Meister
    175
    Sep 2, 2013
    Mount Vernon, Ohio
    Can you put a TMB amp a effects loop in a 5f2h?
  2. tubeswell
    tubeswell Friend of Leo's
    Jul 1, 2008
    NZ
  3. clintj
    clintj Friend of Leo's
    Apr 4, 2015
    Idaho
    Might need a bigger chassis.
  4. fensterman
    175
    Sep 2, 2013
    Mount Vernon, Ohio
    Got the chassis taken care of
  5. fensterman
    175
    Sep 2, 2013
    Mount Vernon, Ohio
    I'm going to try to copy Hoffman amps layout for a 5f2a with a stout tmb front end, then somewhere stuff in the effects loop
  6. fensterman
    175
    Sep 2, 2013
    Mount Vernon, Ohio
    I saw a schematic with the tone stack after the effects loop. What is the difference? Before or after?
  7. fensterman
    175
    Sep 2, 2013
    Mount Vernon, Ohio
    Can someone please check my schematic?
  8. tubeswell
    Jul 1, 2008
    NZ
    Somehow, permission is not enabled to view the attachment.
  9. fensterman
    175
    Sep 2, 2013
    Mount Vernon, Ohio
    Finally, I had to get on my computer to post this
  10. fensterman
    175
    Sep 2, 2013
    Mount Vernon, Ohio
  11. clintj
    Apr 4, 2015
    Idaho
    The value of the V1b grid leak is missing.
  12. fensterman
    175
    Sep 2, 2013
    Mount Vernon, Ohio
    1 Meg, I'll have to get on my computer to fix that
  13. fensterman
    175
    Sep 2, 2013
    Mount Vernon, Ohio
    Fixed the missing Resistor value.
  14. fensterman
    175
    Sep 2, 2013
    Mount Vernon, Ohio
    let see if it lets me upload the corrected schematic
  15. fensterman
    175
    Sep 2, 2013
    Mount Vernon, Ohio
    One more try
  16. FenderLover
    FenderLover Friend of Leo's
    Jun 11, 2009
    Minnesota
    The FX loop level may be a little hot. V1B is a self biased cathode follower with a plate resistor? I would lose the 100K plate resistor. Change the cathode resistor to something like 47K+47K. The output is in the middle of the two, and will reduce the level for the FX loop send.
  17. FenderLover
    Jun 11, 2009
    Minnesota
    With the EQ before the loop, you can obviously EQ before the loop. Without the EQ, it's just a clean gain stage feeding an FX loop and it wouldn't be necessary at all because the FX could just as well be before the first stage.
    FX loops are best placed after distortion producing stages for the same reason. The 5F2 has 2 gain stages, then FX loop, then output stage. YMMV.
  18. robrob
    Dec 29, 2012
    United States
    The schematic is a pdf so unless your device can automatically open a pdf for viewing clicking on the link won't work.
